How do I remove my headlamps?
Old Nov 24, 2006 | 11:32 AM
SDCfla's Avatar
E55 and Carrera S
Thanks, I am sure I have to take the whole front bumper off right?
Old Nov 24, 2006 | 12:54 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Yes The Front Bumper MUST be Removed to remove the headlights...
Its Easy!
Old Nov 24, 2006 | 06:38 PM
glassJAw's Avatar
'01 E55
The bumper doesn't have to be completely removed but it will give you a lot more room. The trick is to loosen the bumper and remove the bolts to the top of the fender so you can pull the fender away with out completely removing it. Also make sure you put masking tape on the fender and bumper around the headlamp area to prevent scratching the paint while removing the headlamp.
