ASP Pulley Install
Rating: Thread Rating: 8 votes, 5.00 average.
Old 12-02-2006, 09:32 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
Steve´s European Automotive Inc.
Waterford,
Michigan
48328
United States
Tel: 248-674-2770
Fax: 248-674-2778
eMail: steve@steveseuropeanauto.com
From their website... so I guess so.
Old 12-04-2006, 06:42 AM
stevebez's Avatar
For those interested the ASP measures in at 7.28" ... stock is 6.3" and Evosport is I believe 6.675" (diam).
Old 12-12-2006, 02:39 AM
Mrdredd's Avatar
Originally Posted by stevebez
Think I will be going with a Wetterauer ecu mapping ... mostly because they sell a full motor/tranny/drivetrain warranty with their mods for up to 3 yrs / 100,000km for ~$500, but also because they are one of the most repsected in Germany as well as being TUEV certified.
Their Sportversion II gets power up to 600hp and 700ftlb...
Sorry to bump an old thread, but ...
The Wetterauer ECU map will increase a stock 55 engine with just a pulley upgrade to 600hp and 700tq??
How does it compare to a Renntech or Kleemann mapping?
Old 12-12-2006, 03:09 AM
stevebez's Avatar
Nope there are "other mechanical components" fitted I presume its a bigger throttle body or / and headers...
Old 01-30-2007, 04:37 PM
Ted Baldwin's Avatar
300ce
..........I have used ASP pulley for over a year now. I think I was the first to combine kleemann K2 with larger ASP pulley. All the caveats about boost and IAT are true, but there is absolutely no problem with everyday driveability. If you are going to use the ASP pulley, should probably upgrade your water pump or intercooler, but this is something you should do anyway in these AMGV8K cars regardless of what pulley you use. I am sure the anoited tuners will bash this pulley, but you have to consider their motives since this pulley is very cheap at $800 only.
Old 01-30-2007, 07:50 PM
phatmitzu's Avatar
2005 E55
Where did you guys get you ASP pulleys from??
Old 02-01-2007, 10:02 PM
  #32
sgtstanko's Avatar
2006 E55
I ordered mine direct. I intend on using a base Superchips tune then using Harmon Engineering to dyno tune A/F. These boxed tunes are ok as baseline but unless you have access to a dyno and a laptop tuner your half stepping.
http://www.aspracing.com/intro.htm
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: ASP Pulley Install
