Outside temp. question.
Old Dec 5, 2006 | 03:20 PM
corgiman's Avatar
E55
The outside temp. monitor on my car starts with an accurate reading in the morning and then the temp. quickly rises 7-8 degrees. When I drive the temp. goes down but rises again when I stop. This cycle repeats until I drive at a sustained speed and then the car holds the lower outside temps.
Normal???
Old Dec 5, 2006 | 03:54 PM
blackbenzz's Avatar
haters crazy
I dont know about the E55 but on the CLK's the temp. sensor is located close to the radiator and engine. Obviously if you are sitting still for a long time the heat from the engine/radiator will effect the reading (higher) of the sensor. Once you start its more accurate because the heat is pushed away from the sensor.
Old Dec 7, 2006 | 08:39 AM
corgiman's Avatar
E55
This actually starts immediately - before the engine is warm.
