ECU Torque/Load Limiter Problem...
Old Dec 6, 2006 | 02:09 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
I'm interested in buying a 2005 or 2006 E55 with the intent to mod, but this ECU Reflash problem is worrying me a lot. I have a few questions for those of you who suffered through this ordeal (or those of you who knows a great deal about it)...
1) Is it certain that the problem is from the ECU re-flash?
2) If it is a limiter hidden somewhere in the ECU, can the limiter itself be modified or pushed to a higher limit?
3) Is there any remedy or "cure" for this problem?
4) Can it be undone? If so, how and how much does it cost?
Thanks...
Old Dec 6, 2006 | 09:37 AM
jcjmw's Avatar
2005 E55 Wagon
Thanks...
I just purchased a 05 E55 wagon, then took it to the dealer for the reflash,then had the car dynoed. I did not notice any difference in power between the before and after re-flash and the post re-flash dyno showed the car producing good power. See thread "Any other wagons out there." I hope this helped.
Old Dec 6, 2006 | 09:54 AM
dsc's Avatar
dsc
2004 E55
The problem tends to be more with 03s and 04s. I lost 70 hp but Kleemann thinks they solved the problem. They reflashed my ECU and I will have it dynoed in about 2 weeks to see where I'm at.
Old Dec 6, 2006 | 10:00 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Well in my '06 with ASP pulley the thing is a freight train ... ECU is stock - for now.
My friend had the recall done on his '04 SL this week and its still flies with ASP pulley in situ...
Old Dec 6, 2006 | 11:38 AM
MB_Forever's Avatar
How about effects on modded cars?
I know there is almost NO EFFECT on the car post ECU recall if the car is STOCK. But what I meant to ask is if anybody with modded cars (Kleemann stage 1/2/3/4, RennTech stage 1/2/3/4, etc..) experienced a loss of power due to the torque limiter that was (aparently) added to the ECU after the re-call? And is there any solution for this problem?
Old Dec 6, 2006 | 08:45 PM
dsc's Avatar
dsc
2004 E55
Mine has K2.
