Pics of 295 PS2 rubbing damage
My new setup:
Front 19 x 9 Bridgestone RE050A 255/35
Rear 19 x 10 Bridgestone RE050A 285/30
The sidewall profile is nowhere near as beefy as the PS2's, It definitely looks like a much better fit IMO.
Jangy, I really don't think you'll be happy with the 295s on 10 inches. If it doesn't rub at static suspension it WILL rub sometime, bumps, lowering, turns. My CCWs have a more aggressive off set and rubbed the outside. Torquey55's ate the inside. Do what BlackC230Coupe says and roll your fenders, get an aggressive offset then go 295s. Just trying to help you out.
#40
2017 S63 Coupe Iridium Silver
Yes there is a way! I am a bit **** and mirror polish my exhaust pipes from the diff to the mufflers every time I wash my car. That way I get a good view of what's going on down there at regular intervals
#41
I have this exact same setup and with ELM, no fender roll and I have no rubbing issues. from what I can gather John is convinced the sidewall profile and strength of these RE050A's is the way to go.
