Inconsistent Power Delivery
Old Dec 29, 2006 | 09:15 AM
MikTrebla09's Avatar
h
Acceleration at WOT usually feels downright scary. However, there are times when the car feels a bit sluggish....to the point where it feels no different from my M3, in terms of acceleration.
Anyone know why this is? Could it be an issue with the supercharger not engaging?
Any input would be greatly appreciated. Thanks!
Old Dec 29, 2006 | 09:29 AM
newton22's Avatar
BMW E39
IC pump.
Come back if not that.
Old Dec 29, 2006 | 09:37 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Get your IC pump replaced!
Old Dec 30, 2006 | 12:40 AM
h
Thanks for the input, fellas. Perhaps I should've mentioned it's an '06 with 7K miles. Does this still apply? From what I understand after a brief search, 2005+ are less prone to the dreaded ic pump issue.
Old Dec 30, 2006 | 12:46 AM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Where are you located? If you are located nearby Fremont, Ca, we dont mind helping you to check if the pump is dead. Let me know.
Old Dec 30, 2006 | 12:48 AM
DFW01E55's Avatar
'14 ML BT
Does it cut power after a couple of hard accelerations?
If so, it's likely the IC pump.
Can you data log? Measure the Intake Air Temp, that's the key indicator. Once it exceeds 240F, you're dead - no power.
