How do you guys deal with camber?
BMW E39
I want to go even lower soon for that sitting on the fender sort of look (Jay's E55 etc.). As that height, you guys are probably running -3.xx degrees in the front? Do you guys just let it roll like that?
2015 S212
I had my car dumped as low as the RENNTech module would go AND I have the crash bolts set at MAX camber and I still want more. I went to the big track at willow and it was still climbing all up on the sidewalls. I drive hard round the truns, so mine wear pretty evenly. I don't even think Jay's has more than 2.5 degrees (max). I also don't think he is having any uneven wear issues.
Just my bit, you'll get others. I love negative camber. Tires are meant to wear out to me, so I don't even care.
I've developed a set of camber plates (top knuckle joint), that you could actually use to increase camber, so it can be done if you really want it.
