Whining Noise from engine
Old Jan 10, 2007 | 03:00 AM
LazyE55's Avatar
E55
Is there anyone out there that has the same problem as i do. When i start up the car in the morning it has a very high pitched whining noise. Sounds like its coming from the belt but not 100%. What do you guys think? Btw i have about 41,500 miles on the odometer...maybe its normal wear and tear? thanks,
Roy
Old Jan 10, 2007 | 05:26 AM
phatmitzu's Avatar
2005 E55
The timing belt/supercharger belt need to be re-adjusted(Tighter).
Old Jan 10, 2007 | 05:35 AM
zdkdeeier493's Avatar
Its normal. Its just your belt and the car warming up the oil. Wait for the RPMs to drop before you drive off in the morning and you're fine.
Old Jan 10, 2007 | 05:36 AM
Finny's Avatar
03 E55 AMG
Smog air pump.
Old Jan 11, 2007 | 02:58 AM
LazyE55's Avatar
E55
Thanks for the inputs. Got worked up for no reason
Old Jan 11, 2007 | 02:59 AM
Finny's Avatar
03 E55 AMG
So what was it?
Old Jan 11, 2007 | 06:07 AM
LazyE55's Avatar
E55
Originally Posted by Finny
So what was it?
Won't know until i take it to the dealer next week.
Old Jan 11, 2007 | 08:55 AM
vader's Avatar
04 E55
Smog air pump.
Bet Finny is right...you will hear it run for a while and shut off....if you idle a long time you will hear it cycle too....I thought it was a P/S pump so I brought it up when I serviced the car this summer. It was the smog pump.
Old Jan 11, 2007 | 09:34 AM
sly55's Avatar
05 E55, R33 GTR, R33 GTS-t
mine has done this since new. not sure if its the same whine as you describe tho. Whenever its cold from first start it whines for maybe 20 secs? then just quickly fades out and you just hear the engine.
Old Jan 11, 2007 | 11:23 AM
vader's Avatar
04 E55
Thats it Sly...
Old Jan 11, 2007 | 11:26 AM
Carl Lassiter's Avatar
'08 M5, '10 Land Cruiser
Power steering is low on fluid is my guess
Old Jan 11, 2007 | 12:31 PM
Finny's Avatar
03 E55 AMG
Must be leaking then...?
Old Jan 11, 2007 | 06:00 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
mine made that noise too dealer said it was normal. (05 E55)
Old Jan 11, 2007 | 07:36 PM
kiwie55amg's Avatar
2004 E55
...not sure about whining from the engine, but I get a lot of whining from the passenger seat.
