Another question.
Old Jan 14, 2007 | 08:29 AM
xlr8tin's Avatar
2011 GL550, 2004 Audi S4 v8
Another question.
I have another question.
I found some wheels online that are 19x8.5 and 19x9.5.
The fronts have a 35mm offset, and rears with 37mm offset at this size wheel.
Will these offsets work on both front and rear? What if I just get the 19x8.5 all around...will they fit alright on the front?
I figure though I may need a spacer in anyway unless I do 19x8.5, I may not need them for rear.
Any insight for me...Thanks
Old Jan 14, 2007 | 11:14 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
should fit easily with 255 and 275 or even 285 tires.
Old Jan 14, 2007 | 06:16 PM
xlr8tin's Avatar
Ok, Should I go for the staggered..should I say can I fit staggered?
Do you think the 35 offset will fit the front and 37 offset the rear, if the front offset is 32 and 35 in the rear.
Old Jan 14, 2007 | 08:56 PM
chiromikey's Avatar
rafal is the guy with the answers but iirc, 30-35 offset for front and 35-40 offset for rears will work just fine.
i'm running 35f/40r on 19x9f and 19x10r with 255/35f 285/30r and it's perfect.
Old Jan 14, 2007 | 10:40 PM
xlr8tin's Avatar
Thanks! You've been a big help, chiromikey.
