Question, wheels and tires
Old Jan 23, 2007 | 12:43 AM
dkallencat1's Avatar
Question, on 19 in. 8.5 front and 9.5 rear amg wheels what do you torque your lug bolts to ? I think the manual said 90 lb. torque does that sound about right, or just tight them down. Also how much air pressure do you guys ran front and rear? 245/35 and 275/30. Thanks for the feed back.
Old Jan 23, 2007 | 08:42 AM
vader's Avatar
04 E55
Torque them down in a star pattern to 130nm which I believe is 90 ft lb. Don't just tighten them down.
Old Jan 23, 2007 | 09:54 AM
vrus's Avatar
2003 E55 AMG
96 lb/ft is what I use and I believe is the recommended factory setting...
I torque them in a 2 step process.. I first torque to 50lb/ft and then I retorque each bolt to 96lb/ft.
Old Jan 23, 2007 | 10:09 AM
vader's Avatar
04 E55
Damn..just recently I saw 130nm on here somewhere...hey Neal......what should HRE wheels be torqued down to ??????
Old Jan 23, 2007 | 05:40 PM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
They should be torqued to the same as the factory recommendation which is just under 100lbs I think.
