Tire width & handling geometry question
1. Having all 4 the same size provides the benefit of being able to rotate them and squeeze more life out of them.
2. Having the OEM spec would be better for handling? How long do the OEM spec tires last (you cant rotate them obviously)?
3. Would I be able to mount OEM spec on the same set of rims or were the OEM rims fatter in the back to accommodate the wider track?
Thanks a lot.
You may want to consider going back to a staggered setup, if you want better traction in the rear.
