Renntech LM
2015 S212
Jangy,
When you adjust on the fly,are you adjusting both front and rear with one knob or do you have to turn seperate knobs?Follow me?Say you have the car slammed down and you want to run it at a higher setting,can you just turn a single know or do you have to go through a big procedure?I understand the cars stock raise lower button still works but can you do all of the raising and lowering from the LM on the fly?
With the Airmatic, each of the fronts has its own knob and the rear has a single knob. So, to answer your question, you have to turn three knobs to raise or lower the entire car (unless you use the car's own systems which still do their thing). The beauty is that turning three knobs is not that hard and you can adjust rake very simply.
Hope that helps.
2015 S212
Alignment is such a particular thing. In reality, your alignment settings would change depending on the track type. Just using the MB settings isn't the ideal performance setting anyway.
E55
Hope that helps.
Hope that helps.
06 EuroElites E55
no there is no marks but that is a good idea. i think im gonna mark mine at the lowest setting i like so if i raise it for some reason i can put it right back down where i like it easy. thanks for the idea bro.
#32
#33
06 EuroElites E55
ya that is how it was set tape measure. i dont move it so i didnt think about puttin marks untill you said that. that got me thinkin if i do move it i want it right back where it was easy.
#34
2015 S212
No way. That is way too complicated. The knobs have a notch in them. When the notches face the front of the car, they ae at the "0" setting. You have 9 "clicks" to use, so it is easy as **** to just do it by feel. Now, if your car is off to begin with, then you may need one front to be a setting above or below the other to make them even. I had my Airmatic calibrated to avoid that. I just use the module to raise and lower, not to adjust left to right.
#35
E55
