wire the ic pump to a switched 12V source?
With that you can run a wire direct to the pump if you have the factory bosh pump. The funny thing about our cars is that the ic pump relay is located in the trunk which makes running a ground switch to cabin a little harder. Hope this helps.
I dont know much about relays and such, so i wouldnt know where to begin on that. All I know is + and -. haha
In short, the only real advantage to doing the rewire is that the car will cool off faster between dyno runs or even before the first run while it is sitting at idle. It all depends what you are trying to do. If you want a real life number, then leave it be. If you want a huge number just to feel better, then go for it.
Since the ECU controls the pump, why don't one of these $3K ECU mods address that?
I am sorry, i assumed you wanted just to test on the dyno from the beginning and not make it a permanent install. Leaving the pump running on the dyno with a fan on will keep heat soak down. If it is long term solution then you need a 30 amp relay and an in-line fuse like sunman said.
You can get a 30 amp relay from the auto-parts store and follow the instructions in the link below. The relay you buy at the store will have numbers just like the one below.
http://www.ado13.com/techs/relay.htm
I got the relay, but mine has two "87 terminals". One is yellow and the other red. Which would I use to run to the IC pump??
Charles, on the dyno you are not likely to see any benefit. How many fans, how big the fans are and whether the shop knows how to run 55s on the dyno will likely determine whether you get proper dyno number or not.
If you need any help call me, I am not too far.
Thanks for the offer
