Driver side air intake hose issue.
Old Mar 1, 2007 | 10:31 PM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
The last two times I have checked under the hood the air hose which connects from the front grill to the air box comes loose. drivers side only. There is no clamp only a dimple in the plastic that seems to 'pop' in to connect. It comes loose near the airbox. The grey plastic engine cover rests near it but that part seems intact and tight. Any suggestions. Can't seem to find any aftermarket intake systems for the E63...only the E55 but the intake systems look so similar.
Old Mar 2, 2007 | 06:44 PM
05VENOM's Avatar
Could it be engine movement. Motor mount ?? The front grey plastic engine cover buts up against it. It is held in by 6 metal clips. Removed it but everything seems OK.
Old Oct 12, 2019 | 11:06 PM
Saurabh914's Avatar
E63 AMG 2009 E55 AMG 2005 E63 AMG Wagon 2007
did you ever find out what’s the cause? Mine has started to come loose on the driver side too
