Thinking of painting the e55
As long as you know resell value will plunge on a repainted E55, you'll be fine. The colors will also be non-matching on parts of the engine bay and inside of doors etc.
I hope this is a lesson to all the black car owners that get the cheapo details!!
for wantin to re-paint your entire car Like others have said, just find a reputable detailer in the area. I doubt you need re-painting unless you've been drying her off with sand paper. Don't get me wrong I hate swirls on black too, prolly the worst thing about black paint, but try the detail route. Good luck
But ask couple people here who have seen my car.... they're all clean and only minor swirl marks on the E and almost no swirl marks (extremely minor) on the C. Both are black....
But yeah, I spent like 3-4 hours washing one car.... rinse the mitt every one stroke per side.... only do one pass per surface.... vertical strokes.... use wax 'n dry from Eagle One.... one stroke to dry the surface. Tiring... but hey, I save money to buy gas and drive the car... haha...
Bake for 2 days, done.
If you want to do it your self go to properautocar.com and read up about removing swirls from your car and what you will need to get the job done. My SL55 is black and when I take the time to remove the swirls once every 6 months it looks FANTASTIC. I "wax" the car every time I wash it but any time you touch the pain on a black car you end up with swirl marks. It does help to do the 3-4 hr car wash with rubbing in the same direction but that even still leaves marks if you look closely. I use recommend the Menzerna line of polishes for ceramaclear paints and then blackfire wet diamond synthetic wax to shine and protect the paint. Having used everything from Pinnacle to Zaino, I think blackfire's Wet Diamond is the best all around product. Zaino is great but it really lacks any sort of depth and makes a black car look as if it were made from plastic. Menzerna FMJ makes a black car look as if the paint is 1 mile deep (same with Pinnacle Sov.) but it lasts no where near as long as zaino and Wet Diamond.
Get the car detailed and or color sanded and then take a little care to keep it looking great once every 2 weeks and it should always be fine.
One tirck with black is to just let it get dirty and wash it only when you must. Washing it will always put swirl marks in the paint regardless of how careful you really are. Also when you do wash the car use a leaf blower to glow all the water off the paint rather than drying it with a microfiber towel. You will still have to go around and get the left over water but this reduces the rubbing by say 90% and that will save your paint as well.
I live in southern MI where there's a TON of granite dissolved in the water. To address this I bought a deionizer setup from Costco for 400.00 which I use at home. This lessens the trips to the bay wash.
Try to avoid touching the body at all costs. Mine is Pewter gray so it's not as touchy as black. I had a 2001 M5 in carbon black and that fixed me for black paint forever! Here is the info from the website-hope this helps and DONT repaint your car unless your giving it to your 16 year old!
CR SPOTLESS De-ionized Water Filtration System
Spot-free Rinse System;
No Drying Required
$419.99
Item # 180790
