Front brake job estimate
Audi Q7
I have 25,000 miles on it and brakes are running low.
Do i need to change both pads and roters? And what is an estimated cost from a dealer or ID shop.
My dealer queted me appr 900 bucks and he said he will give me 15% off.
Sounds right?
Sounds right?
07 S65
What ever happened to replacing your own brake pads. I may be wrong, but I find it hard to beleive a 25,000 mile car needs rotors.
I just replaced the front and rear brakes on my high-maintenance daughter's Volvo S-60t and the total cost was $70. This car had 45,000 miles on it, and while there was some wear on the rotors, I saw little reason to throw the rotors away.
Guys - correct me if I'm off base, but after 25,000 miles - pop on a new set of pads and cruise on!
Barry
Barry
I have been changing my brakes on my Porsches for years without doing this. Mainly when changing between track pads and street, but also just worn pads.
I don't think that's a requirement for changing pads.
E55
On crossdrilled rotors, I'm not sure if you want to turn the rotors; at least, the vendor doesn't recommend it. If the surface is pretty even, I would just slap on new rotors instead of turning them.
04 E55
I don't know about hi performance slotted or cross drilled rotors...but putting new pads on a glazed rotor can't be the best solution. Does MB recommend new rotors with each pad change ???
2006 ML-350 and 2007 ML-350
Barry![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Barry
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
I don't want to be a butt head but if you are going to replace your pads yourself please at least measure the rotor thickness. If it was my daughter’s car I’d make sure the car was safe after I decided to do the brakes whether I did them or someone else did them. If you never done this before at least get a manual and read how to do it correctly, there are a lot of people here that although have good intentions and the ability to replace the pads themselves have no idea what the hell they are doing! You are talking about a car that weights at least 4000 lbs; someone can get killed if you decided you wanted to save some money. There is a minimum recommended rotor thickness for safe braking. Although the rotors may be thicker than the minimum please look at the wear and see if the rotors will still stay above the minimum thickness during the full life span of the next set of pads, many times this will not happen. And that is just one reason why rotor replacement is recommended. Most German rotors are inexpensive! Also most German brakes have very soft rotors (this is one of the reasons they do not warp as easily) so please do not compare these to other makes! And yes it is very common for rotors to need replacement on these cars whether the pads wear out at 10,000 or 50,000!
I’m a tight wad just like everyone else but if it is going to be a safety issue that I am working on, I sure as heck will find out the correct way of doing the project not just the cheapest.
And argue all you want but brake pad wear is directly related to driving style!
![Argue](https://mbworld.org/forums/images/smilies/argue.gif)
Like I said in the beginning sorry for being a butt head.
I used to teach the new techs in my shop and some of them think just because they have tools and can unbolt something they think they can do anything. Pretty bad results sometimes. And these were kids who wanted to work on cars!
Rant off
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Rant off
And argue all you want but brake pad wear is directly related to driving style!![Argue](https://mbworld.org/forums/images/smilies/argue.gif)
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Actually, it's not a good idea to machine the rotors on today's cars because they only heat treat the surface of the rotor to save $$. If you machine it, you just took off the heat treated surface and they won't perform or wear properly. I sure as hell aren't going to replace my rotors at 25,000 miles unless they show some serious wear. Swaping pads until the rotors NEED replacing seems OK to me.
I was just told by my SA that the brake pad is ~$500. And currently, the pads are difficult to find.
I'm getting my pads replaced because of the brake squeal, under warranty of course.
Audi Q7
Um... MB dealer said that rotors where low. 34.1mm
So going to do both pads and rotors and he gave me 20%off.
Matching the price of a local independent Mbn shop for $800.
You normally can get away with not changing rotors every time you change out the pads. When I had it done I just did all 4 wheels and both pads and rotors because I figured it was a good idea. Then again I only paid $700 for the entire brake job (installed - pads and rotors on an 04 E55). When you are talking about paying full bore for the job doing just the pads seems far more logical.
See if you can't get a better deal on the parts.
Also doing it yourself risks losing a finger. There is a list of 20+ items that can prime the SBC pump for fun and if you happen to be working on installing a pad and the pump sends 1500 psi of pressure through the system you will likely lose a finger. I did the brakes on my old cars but I paid to get my E55 done for that reason.
Former Vendor of MBWorld
W211 E55
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Can one not simply unplug the SBC before the swap?
2015 S212
I'm also one that does not do my own wrenching on critical components, but I can see where some may want to. to place a blanket statement that is is an intricate job and so nobody should do it is somewhat narrow minded.
Just for the record, I swap out rotors and pads each time. But, then again, I consider them as a disposable set.
People do change their own pads and good for them but I dont choose to do it and that is far from narrow minded. Its a warning to people who dont realize that someone walking past the car or within x feet of the car with a keyless go key in their pocket can prime the pump. How about if you turn the front wheels more than x degrees either way while working and the pump primes? Bye bye fingers.
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
The brake issue is just one reason I dont end up tracking my E55. I dont want to pay to get pads swapped out all day long when every other car is a do it yur self kind of job! I did the brake jobs on all my other cars but the E55 was the first time I said oh whatever. I just happened to have 200 lbs of pads and rotors in the trunk of my car when it went in for a service with an envelope with 200 bucks in it. When I got my car back it had new pads and rotors all around and I was missing that 200 buck envelope!
