Offset question for aggressive setup
Minimum et35 in front and 40 in rear should be fine. The tires is what rubs, so tire size has lots to do with choices.
As for tires, I was considering 235/35/19x8.5 and 265/30/10 (for that stretch look)
Tire size and style does matter.
If you were to read my question, again, I was asking about offsets. Why would it matter if I'm using +30, +40, or even -10 offsets?
Simply, on a 19x10/275 tire, a lower OR higher offset - tire size will not change.
Believe it or not, I can run the same size wheel and tire, but with different offsets;
* 275 fits a 10" (T1Rs will be stretched)
19x10 on 275/35/19 +32
OR
19x10 on 275/35/19 +30
OR
19x10 on 275/35/19 +28
OR
19x10 on 275/35/19 +25 (max lip)
That is an astonishing revelation isn't it?
Wheel/Rim width = Tire width. Tire width's don't factor in with offsets. Unless you are talking about JDM VIP, which I highly doubt, then that was another story.
The purpose of my question was to figure out maximum rim width and the lowest possible offset. Hence, my thread is entitled "Offset question - aggressive setup"
I'm not here to flame. Like many others, I'm here to research and learn. Next time, consider the facts before calling out newbs or (wnewb).
P.S. To learn more about offsets, visit www.tirerack.com.
on a 19" rim with a 40 offset you can run 285's, maybe even 295's. try that with a 30 offset and you'll rub. put a 265 on that same 30 offset rim and guess what...it fits. (for simplicity's sake i'm not addressing aspect ratio which could also play a role.)
