Active Headlights - Are they working?
Old Apr 9, 2007 | 02:57 PM
J 2OOI's Avatar
2012 JDM
Exclamation Active Headlights - Are they working?
I have an 04 E55 with the 319 Lighting Package and I am not sure if my lights are functioning correctly.
I have been in a friends BMW 530i and his "active" lights are much more active than mine. In fact, mine don't even appear to move at all. I have heard the BMW's require the lights to be set on "Auto" for the active part to work, so I have tried that on my car to no avail. (I normally turn my lights on manually so I can have the fogs on)
Also, with the BMW, the active lights still work even when the car is in park. Turning the wheel shows obvious movement in the lights. I have read that the MB's must be moving for the active lights to work. So I have set my lights to "Auto" mode and driven and have still not seen movement.
For those of you with the lighting package, is it easy for you to tell that your lights are turning when you turn the wheel? Should I expect to see the lights moving like in the BMW?
Old Apr 9, 2007 | 03:07 PM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
I normally see mine react when I turn into my driveway. If you have a wall or other obstacle that you can judge agaisnt, that's the best indicator. Otherwise, I only notice them when the road is not well lit and very twistie!
Old Apr 9, 2007 | 03:19 PM
Hazy1's Avatar
'03 E55
I have an '03 with the lighting package and no "active" headlamps. I might be completely wrong, but I don't think '04's have active lights either.
Old Apr 10, 2007 | 10:24 AM
Dogshine's Avatar
CLS55
go into a parking garage with ramps. you can see them moving on the wall as you turn the ramp going up or down the incline
Old Apr 10, 2007 | 10:27 AM
Benz-O-Rama's Avatar
04's definitely have them, mine does. They won't move unless you're rolling. I think you have to be going faster than 10 mph? Something like that. I can definitely tell mine are working on dark twisty roads. Obviously on straights or lane changes, you really can't tell.
Old Apr 10, 2007 | 12:48 PM
psk145's Avatar
2006 E55
my 06 has them, but I dont notice them working at all
Old Apr 10, 2007 | 02:41 PM
J 2OOI's Avatar
2012 JDM
Thanks to everyone who replied!
After I saw the post from "Hazy1" it really got me wondering if my lights were actually "active" or just bi-xenon. Glad to hear Benz-O-Rama say the 04's are active.
I was hoping to get a response from Scott in H-Town since he has owned an M5 and can compare the two with regards to how "active" the lights are. I will probably send him a PM about it later if he doesn't respond under this thread.
Also, my sister has a new Lexus IS 250 (I know she should have got the 350, but she is only 20, so not bad). Anyways her lights are also much more "active" than mine: I can clearly see them moving when she turns.
Old Apr 10, 2007 | 04:13 PM
starbrite's Avatar
2004 E320
My '04 320 has active and it is very difficult to see when they are working.
Very mild effect IMO.
