EOM e500 rims on e63?
Old Apr 22, 2007 | 05:07 PM
AMGrateful's Avatar
Ok, I'll admit I haven't done a bit of research on this, but I was just wondering- would it make sense to use my OEM 17" wheels (still gathering dust in the garage) from my 2003 e500 as the home for a set of DRs? Would they even fit?
If anyone has any input on this, I'd appreciate it!
Old Apr 22, 2007 | 05:48 PM
TPowerdinNY's Avatar
996TT
I am sure that they won't clear the brakes. U should get a beater set of 18" wheels and some michelin pilot cups... that will be an awesome set
Old Apr 22, 2007 | 06:18 PM
jangy's Avatar
2015 S212
You can try a test fit, but te brake calipers are the issue. I know that CCW made a custom set for someone back in the day and the big challenge was clearing the calipers. It can be done on a 17, but I don't know that an OEM 17 would do it. Also, that OEM 17 is probably not wide enough to put some good patch on. I would recommend a second set as well.
Old Apr 24, 2007 | 01:09 PM
Alex@Creative's Avatar
ABT B7 AS4 & 07 S550
we have done the E55 Brake conversion on a standard E500 and unfortunatally those OE wheels do not clear the brakes. The calipers are far to big.
shoot me a PM if there is anythign else i can help you with and also if you want some quotes for wheels
