••• Project Stock to Awe •••
Rating: Thread Rating: 6 votes, 5.00 average.
Old 10-09-2008, 01:25 PM
  #276
Finny's Avatar
03 E55 AMG
Smile SLR Cooler update...
Just some work done so far for your amusement...
The original SLR cooler inlet plumbing was to wide to fit in our 55's bay so via a Mac 3D cad application I designed an alliterative inlet that wouldn't be restrictive due to loss of space.
The solution was to swing the main cavity section down and ramp it towards the front of the engine preserving the same flow characteristics. After taking some reference shots and then placing them into the CAD app with some measurements I then constructed a new inlet manifold to fit like a glove.
I personally don't like Frankinstine alloy tig weld box styles so thats why I went with this method instead.
After being happy with the computer model it was then saved out and sent to a company who specializes in 3D printing. The printed models were returned for mock fitting and trimming.
From these models I'll have casts made to be welded on the original coolers and then finished off with the factory style powder coating.
Check out the following shots...
Reference images in MODO 3D.
Must take advantage of this space here without restricting flow. Vertical line represents bay wall.
Looking forward, note the stock filter inlet location in relation to bay wall.
Approximate location.
The two join sections will be removed from final casting.
The restrictive stock core will be replaced with a hollow box section along with the removal of the temperature sensor mounting boss. (just to the right)
Original SLR inlet entering horizontal.
Comparison, Stock Right and chopped SLR Left.
No cooling restriction here...
More latter...
Old 10-09-2008, 02:12 PM
  #277
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Excellent work Finny!
Does the SLR have a "hollow box section" underneath its supercharger?
Old 10-09-2008, 02:21 PM
  #278
Finny's Avatar
03 E55 AMG
Yes... Hollow as a log...
Old 10-09-2008, 02:31 PM
  #279
Havoc's Avatar
Wow! Interesting!
Are the intakes on the side of the supercharger the same size as our 55s? They look very similar in size.
Old 10-09-2008, 02:38 PM
  #280
Finny's Avatar
03 E55 AMG
Same rear section cast.
Old 10-09-2008, 02:43 PM
  #281
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
Finny...thank you for the info and the pics. That is fantastic work!
Old 10-09-2008, 02:48 PM
  #282
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
Finny, you're a genius! I love watching your post.
I can't wait to see that beast on the street.
Old 10-09-2008, 02:58 PM
  #283
Havoc's Avatar
Thanks for the info.
The SLR is built similar to our 55Ks than I thought.
Will the front mounted Heat Exchanger work together with the addition of the top mounted intercoolers?
Old 10-09-2008, 03:27 PM
  #284
Finny's Avatar
03 E55 AMG
The existing front cooler core under the front bumper is quite small IMO thats why I made my one the same size as the radiator and very thin to get the heat out as fast as possible... More area and water pressure = more efficient induction cooling.
You could get away with the stock system re plumbed and an extra pump but if you're going to invest in these babies it would be counter productive. My setup will have the big area radiator installed.
Old 10-09-2008, 03:30 PM
  #285
AMGfan's Avatar
Old 10-09-2008, 03:36 PM
  #286
Havoc's Avatar
Got it!
Awesome pic!
Old 10-09-2008, 04:08 PM
  #287
Jakpro1's Avatar
2003 E55 & 2014 GL550
Like metal ****!! Thanks Finny!!!
Old 10-09-2008, 04:13 PM
  #288
JosephLINY-E55's Avatar
2005 E55 AMG
Wow I'm speechless... Finney you are amazing!!!
Old 10-09-2008, 04:18 PM
  #289
Fleebee's Avatar
S211 AMG
i've got a new desktop pic.
Cheers mate.
Old 10-09-2008, 04:42 PM
  #290
Finny's Avatar
03 E55 AMG
Cheers mate.
I'll put a few more up latter...
Old 10-09-2008, 07:19 PM
  #291
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Found some cheep late model head lights on eBay the other day with the intent of updating the look of my 03 but unfortunately the connectors and electronics were incompatible with my 03 setup.
All is not lost though as the plastic lamp covers and LEDs were brand new so I swapped them out and transplanted the factory LEDs to the old units.
My existing clear covers had seen better days and now look brand new for a portion of the cost of new units. The parking or pilot lamps now match the same color temperature of the main projection lamps via the factory LEDs and optics.
Those with the earlier model style lamps could possibly order the LED modules as spare parts and fit these yourself. I'm not sure though if these items are available as a separate part from the light assembly. May need to investigate.
The money shot! Switched on with new lenses... "Lovely"
I like it Finny! here is a little mod for the high beam you might want to consider, as long as you may have the spare parts for it.
https://mbworld.org/forums/w211-amg/248575-anybody-know-what.html
Old 10-09-2008, 09:38 PM
  #292
c32used's Avatar
LET C32 2002
Old 10-10-2008, 01:50 AM
  #293
Finny's Avatar
03 E55 AMG
https://mbworld.org/forums/showthread.php?t=248575
Awesome mod, now I know what to do with the left overs... I'll try and fit them.
Thanks!
Old 10-10-2008, 07:31 AM
  #294
cls55's Avatar
thanks for sharing
Old 10-27-2008, 06:38 PM
  #295
2005 E55 AMG
Dear Finny: Who made you those awesome headers! I need a set true 4 into 1 as best as I can see from the pics very sweet. I cannot wait to see how much power your BEAST produces! Very best regards, Joseph
Old 10-28-2008, 06:11 AM
  #296
Finny's Avatar
03 E55 AMG
Put together by a local exhaust guy. Custom fitted, where the top of the cat was cutoff and rejoined with an 75-80mm 4 bolt joining plate. I believe the stock hole is around 50mm causing a bottle neck. The secondary cats and resonator were deleted too. Sound is still reasonably quite but the SC is friggin loud! Love it!
Trying to fix some software bugs at the moment but the road test... Off it's face! spin in 1st 2nd and 3rd... base dyno soon without SLR coolers once software is ironed out.
Old 10-28-2008, 09:45 AM
  #297
2005 E55 AMG
Finny that is amazing spinning in 1st 2nd and 3rd gear!!! Did you also plan to put in a LSD like Quaife or such. You are going to need it to stay somewhat straight while you blast down the road like a rocket! Great job, I wish your exhaust fabricator was here in the states I would definitely buy a set or a bunch and sell them over here!!! Do you have a goal in mind for RWHP And TQ numbers?
Old 10-28-2008, 02:44 PM
  #298
HAHA BYE's Avatar
2003 E55 Blk/Blk
How much did he charge you to make those headers??
Old 11-01-2008, 10:34 AM
  #299
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
THANK YOU SO MUCH FOR THE EXPLODED VIEW
Finny, I'll never keep saying thank you for long enough
but, if I remember well from the beginning of the story, your plan was to cut the SLR inlet .. enough to fit the 55 bay: something similar in the image below, I think.
sure, would have remained the problem of mismatching between the stock core and Original SLR inlet entering horizontal ...
as you plan to replace the stock core with a modded hollow box, why not sImply modding the box's outlets to match original SLR inlets, ( or using original SLR box, duly modded for by-pass valve difference) too ?
- ... and our HOOD should be cut the same way as in that arabic car?
can't wait to know your solution for intake Ypipe and filters location
[IMG][/IMG]
Old 12-16-2008, 07:35 AM
  #300
S 500 R's Avatar
C43 T AMG -98, 500E RWR -91
This was intresting reading...
Have something hapend whith the car???
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: ••• Project Stock to Awe •••
