03 E55 check engine light!
Old May 6, 2007 | 05:08 AM
STOCK E55 W211's Avatar
03 E55 W211
just bought 03E55 drive for 3weeks my check engine was on, and the shop replace the air pump. but it was only good for 2 days ,then check engine light show up again! reset the check engine light and it's keep come on over and over ( same error code every 2day) . please give some advice on this air pump ?? thanks
Old May 6, 2007 | 05:21 AM
OzE55's Avatar
2003 E55
They must replace the relay as well, otherwise the airpump will burn out again (if it hasn't already).
Old May 6, 2007 | 05:22 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
do you know the actual fault code?
Old May 6, 2007 | 05:52 AM
03 E55 W211
no, they just told me it''s the airpump . and they replace a new airpump too. probably the relay doing bad ? because they didn;t replace the relay. thanks
