Tire pressure reset
M3 1999, Porsche C4 2002, E55 2003
Tire pressure reset
I have had my tire pressure reset atleast 3 times. I keep having this malfucntion show up every 2-3 weeks. Can anyone help me with this?
If you keep resetting and continue to get a malfunction with TPMS then you might have a bad unit in one of your tires. (I had two that were replaced under warranty at the same time.) I am assuming that the problem is not a bad tire. I had a slow leak once that kept triggering a message to check tire pressure, which also required a reset.
