Octaine Boosters...
Octaine Boosters...
What do you guys think about Octaine Boosters ???
I have tried NOS octaine booster...I not sure and cant really say if it helped ME run better at the track...or made my beast to perform better...
Anyone uses them for 1/4 racing ???
Do they help to make more POWER bringing octaine number 1-6 numbers higher (deoends on the booster)...
Let know what you know...
the only one I know if is Torco Accelerator that is clamied to work, i use their race gas with excellent results, I just havent purchased this yet but ordering some this week.
'06 E55, '05 SLK55, a few others
Doesn't matter if it's higher octane fuel or a booster, it won't do anything for the car if it isn't tuned to use it. IF your car isn't pulling timing now, higher octane will slow you down. Higher octane just means the fuel burns slower (more resistance to detonation). This has been beat to death. Considering what you have into the car and the state of tune, you probably will get no benefit from increased octane unless you re-map the ECU. The bad thing is that let's say, you do extensive testing and find out that about 100 octane is the most the car will handle without driveability and/or starting problems no matter what you do with the ECU, boost, and/or injector sizes. You consistently run 100 octane and have now gained another 15-20 RWHP. The first time you get stuck with some pump gas at say, 94 octane, your car is going to be very upset. Octane boosters do more for the people selling them than anyone else.
I've used the NOS Octane Race Booster (the black bottle) in my CLK500 and I could have sworn that it works...my ECU is set for 93 octane. I used to put it in with 93 Octane.
On the bottle I think it said in bold letters and bright colors that it contained "Nitro-methane," not sure if that means anything.
Some people have installed a switch where they can change their ECU tune from normal octane gas to race fuel. Might not be a bad thing to ask your tuner about.
read the fine print. when they claim they raise octane by "x points", their definition of "points" is NOT the same as the octane rating of the fuel. in reality boosters only raises fuel octane by about 1/2 of 1 point.
VERY dishonest/misleading or great marketing...you make the call.
Former Vendor of MBWorld
W211 E55
chiromikey is right.
Their "points" are one-tenth of an octane point.
If they claim 3-5 points, expect to go from 91 to 91.3/91.5
I wonder how many freshly-turboed ricers have grenaded their motors thinking they were running the equivalent of c16.......
Or how many others are suckered into thinking this actually increases performance. Unless of course, once again folks, the car actually needs and is tuned for increased octane. PT Barnum would be proud.
Ok...this is jsut what I thought...my car is tuned for 98 EURO fuel...I run mainly 98 Ultimte which rates from 98-99.8 octaine numbers...so booster wont change anything...
'03 G500, '13 G63, '17 GLS63,
The NOS Racing octane booster in the black bottle was proven to work in an article I had read. Unlike others who raise by "points" it was purported to raise octane by much higher degrees.
Privet Vadim...
But will it work on my car ??? I thought ECU need to be adjusted to make more power...
P.S. Sorry for not calling you been very busy last week...so as I have some good news I call you immediately...
2009 E550 w P1, Flint Black
There's no measurable slowing of the burn rate (ie, flame front).
In CA, premium gaso is 91 octane and yet the cars are tuned for 93. In this case, octane boosters (or race gasoline) will help get the full potential from your engine.
- A chemical engineer in CA -
SL55
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
Bravo,
You are absolutely correct. To Put it more simply... Higher 0ctane raises the temperature at which the fuel burns.
If you don't need the anti detonation factor you will lose power with high octane fuel... With regular you get faster more complete burning. I remember learning this lesson while a youngster drag racing my old Kawasaki 750 H2 Two stroke, It actually ran a tenth and a half faster on Regular!!!
Best,
RoydRage
E55
Skip the octane booster. If anything, the one that I use a great deal and works well is the Redline SL1 injector cleaner. Techron is not too bad. Octane booster is a waste of money unless you want to increase octane by 0.2 to 0.3.
What I would do for added octane and I have used before is:
Toulene
R+M/2...114
Cost...$4.50/gal
Mixtures with 92 Octane Premium
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $5/gal at chemical supply houses or paint stores.
Toulene
R+M/2...114
Cost...$4.50/gal
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Correct
Not correct. Higher octane means it's less prone to auto-ignition. In other words, the fuel is less likely to auto-ignite when it's injected into the cylinder and mixed with the hot air. Heat is the key as all fluids (think of air as a 'fluid') heat up when compressed. The key is to get the maximum compression ratio with-out causing the fuel to ignite before the spark fires.
W210, W220, W163, W164, C6
For OTC stuff, I like the Lucas brand octane booster.
