Oil Catch Can Installation
#51
Can you elaborate a little more besides "I would not do it".. i have had the covers off and there's aboslutely no pressure coming out of the 2 smaller hoses. the big one, YES.. the vacuum from the intake is what keeps sucking the oil out of the valve covers, so there is no pressure at all. When i blocked them off, the car ran much smoother and quieter.
I would still leave the main big hose (2nd hose on driver side) on as that one does build a little pressure.
thoughts?
thoughts?
#52
quick question guys.. what is the pro and con about just blocking off the outlet from the valve covers completely? i don't see the engine building a lot of pressure there.. I tried doing it tonight by hand and after a bit, still no pressure. even raving the engine up. any thoughts??
thanks
thanks
When the engine is under boost you will get a lot of pressure that needs to be released...
#53
thoughts?
thoughts?
#54
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
also, we are talking about lower end of the motor, where the pressure "should" be minimal.. unless of course you have a lot of bypass.
#56
Bumping this up to ask a question. On the accordion snorkel there is a tube that comes from the valve cover on the driver's side. Could we not just route that tube into a catch can to avoid oil getting into the filters/intake? Just a simple hose from there to a can?
I don't fully understand PCV so please help me here.
Regards
Regards
#58
'06 E55
Did anyone come up with a good solution for a throttle body with no inlet port? What can/parts did you use?
I'm thinking about adding an inlet port on my homemade intake for that fat tube on the drivers side.
#60
2006 E55 AMG , 2005 Clk55 AMG , 2009 Range Rover Vogue
Hello , I have been wanting to install a catch can as well buy have been a little confused as to which hose is connected to the can . Is it the larger one that connects to the air cleaner or the 2 smaller ones that come off of each valve cover ? Man if you could shed some light on that , I would be greatly appreciative ! Thank you so much for you time . I am new to the Forum but not to the E55's . Thanks again .
#62
Its the two smaller ones that come off of each valve cover. "T" those two together like it shows in post #12 above, run that combined hose to the can inlet and then one from the can back to the factory "T" under the throttle body. Make sure to block off one side of the factory "T." I made a custom bracket for my can and mounted it right behind the driver's headlight housing. It works well and is already catching oil.
#63
Man ! , Thank you so much for explaining that for me . I have been struggling with that for some time now . I'm not sure why I've had such a mental block on this project but I am very appreciative of you taking the time to reply that info to me . Thanks again . I have a double style can so I can use one for each side . I will post some pics when I'm done .
#64
One more dumb question , What should be done with the fat tube . I have a cold air set-up going on and it does not have a port for that hose . I would assume to just block it off ? Or am I wrong ?
#65
#66
I wouldn't feel comfortable blocking off that valve cover fat tube port. Maybe others can chime in if it's okay to do.
#68
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
Where would the optimal spot to place the catch can on a 07-09 E63, so that the oil in the can, could be easily drained?
#70
I wouldn't block it off but I can't see no harm in running it to a 2nd catch can
