Summer Window down
There should be a sensor on your driver side door handle. If you aim your key at it when you are holding the button down it should work. I'm not sure if there is a sensor on the passenger door handle (car is at home in the garage). Holding lock will roll them back up.
Hold the keyless go button while pushing the button on the inside of pull handle. It'll roll down all 4 windows 1/2 way and turn on your ventilated seat if equipped.
I made a quick vid of it.
http://www.youtube.com/watch?v=EsDlzx7cArw
