euro command help PLEASE!
what is the difference between these 3 units? im assuming all 3 play dvd n motion and mp3? PLEASE HELP I do not want to purchase the wrong one!
BE 7039
BE 6061
BE 7023
BE 7039
BE 6061
BE 7023
E220 CDI (W211)
Here's the pin-out of the connectors on the back of the unit.
Connectors on the back:
The EURO spec COMAND APS unit (Model No.: 6061) has 4 connectors on the back:
1 - Green FAKRA - Video Input - Connector for the TV tuner (FBAS)
2 - 25-way D-Type - Rear Screen - Connector for rear entertainment
3 - 3 Way - AUX audio input - AUX socket in glove box
4 - Multiway - Power, Ground, Wakeup & MOST fibre plug - Connector MOST / voltage supply
Connector 2:
1 Ubat+ (circuit 30)
3 AUDIO R
4 AUDIO L
6 CAN Low
7 CAN High
8 CVBS (FBAS)
14 Circuit 31
15 AUDIO screening
16 AUDIO ground
20 AUDIO GND CYBS (FBAS) ground
** All other pins are not assigned
Connector 3:
1 Low frequency R
2 Screening
3 Low frequency L
AUX IN cable for connector 3 (3.5,, mini female plug on the other side of the cable):
A2115409910
Connector 4:
1 Circuit 30
2 Circuit 31
3 Wake up
4 Not assigned
R MOST receiver IN
T MOST transmitter OUT
Regards,
Miguel
