Is this a joke?
Old Jun 18, 2007 | 06:25 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
Is this a joke?
http://www.m5board.com/vbulletin/showthread.php?t=98587
Old Jun 18, 2007 | 06:32 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
why would it be? there are valid benefits to using nitrogen.
Old Jun 18, 2007 | 06:38 PM
NSM's Avatar
NSM
SL65
The last set of tires I got on the tire company used nitrogen. They fill them up whenever I need it. They claim better pressure retention..
Old Jun 18, 2007 | 06:39 PM
SLK55R's Avatar
ah
what are all the benefits of doing this?
Btw I never heard of this ... guess you really do learn something new everyday!
Old Jun 18, 2007 | 06:53 PM
whoover's Avatar
'19 E63S sedan
The main benefit is that it leaks down through the rubber more slowly than air because nitrogen is a larger molecule than oxygen. But since air is 80% nitrogen, the effect is small. The other touted effect is less pressure variation with tire heating. This is caused by water vapor in air, which expands more rapidly with heat than other constituents of air. This will be less of an issue in dry climates than humid ones, and the benefit presumes that the nitrogen has been dried before bottled. It's not true that NASCAR team universally use nitrogen. Some do while some believe it's a myth.
To each his own.
Old Jun 18, 2007 | 08:16 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
All Jet air craft are FAA required to use nitrogen in all tires.
My TPMS now works with unreal accuracy.
I use it in our inflatable RIBs and get less pressure drop at night.
To me the biggest benefit is the thermo stability.
Old Jun 18, 2007 | 08:25 PM
W211 Ryda's Avatar
2004 E320
Costco inflates your tires with nitrogen....just look for those green valve covers.
Old Jun 18, 2007 | 08:36 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Originally Posted by Yacht Master
All Jet air craft are FAA required to use nitrogen in all tires........To me the biggest benefit is the thermo stability.
I didn't know that about the jets - cool.
+1 on the thermostability. On a set of R-comps, there was about a half-PSI increase after a full track session, as opposed to almost six (from cold) with an air fill.
Not all of the Bmw guys are full of it. Just the ones that frequent our boards, it seems.
Old Jun 18, 2007 | 09:04 PM
dsc's Avatar
dsc
2004 E55
Not only does it have all the mentioned benefits but it is also suppose to keep your tires cooler while in use. All the benefits are suppose to add up to less tire wear. I have had it for about a year.
Old Jun 18, 2007 | 09:19 PM
kovachian's Avatar
I'm gonna put helium in my tires
Old Jun 18, 2007 | 09:26 PM
RJC's Avatar
RJC
Various
Good one!
Old Jun 18, 2007 | 09:34 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Originally Posted by RJC
Good one!
Would have agreed but saw it on the M5Board last week on that thread "excuses AMGers use when they lose to the M5." SLK55R started the reverse one in the W211 forum- amusing stuff.
Old Jun 18, 2007 | 09:45 PM
JokerzWld's Avatar
2014 GL 350 on order
Here in southern MI our Discount Tire shops all use nitrogen for new tires. Better thermal stability,slight improvement in gas mileage and less mucking with the pressures over the seasons-Joker
Old Jun 18, 2007 | 09:58 PM
Drop-a-Daimler's Avatar
2006 C55 AMG, 2.8L Quattro, Softail Nostalgia 1550 (Stage III), Sporster (slammed)
I have been using a 78% nitrogen mix in my tires since the 1960's and haven't had any problems. I'm a big fan.
PS: Air is 78% nitrogen.
Old Jun 18, 2007 | 09:59 PM
dsc's Avatar
dsc
2004 E55
On a serious note, I questioned using helium, it's enert and lighter than air. But the thermal stability is poor. It expand and contract dramatically. Your tire pressure changes too quickly.
Old Jun 18, 2007 | 10:55 PM
AMG_55's Avatar
mymbonline
anyone know of a place around la w/ nitrogen tanks
TIA
Old Jun 19, 2007 | 08:33 PM
kovachian's Avatar
But that's not why I'd put it in my tires!
Old Jun 19, 2007 | 08:51 PM
mfissel's Avatar
2020 C63S Coupe
fletcher jones starting to carry at their stealerships
Old Jun 20, 2007 | 02:15 AM
MidniteBluBenz's Avatar
540 6spd
TIA
Costco
