Engine needs a rebuild. What to do?
All KLEEMANN products are covered by a one year guarantee. In the unlikely event of a component failure, KLEEMANN offers a 12 month warranty period fro all components fitted correctly. Upon installation, the compressor and its parts are guaranteed by KLEEMANN for 12 months or 100.000 km/60.000 mls, whichever occurs first. Extension of the guarantee period will take place according to the law in the respective country where the product has been sold. Your local KLEEMANN dealer will be pleased to give you all the information applicable to your conversion
They can't repair your engine for less than $16,000??
The dealer can tell you "buy a used engine" all they want... There just isn't an abundance of these around. Good luck with whatever you decide..
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWD1V
It really is a very strong engine or it would have done the big end bearing as well and thrown a broken conrod through the engine block.
I have seen this happen, and it ain't pretty!
Sorry about you loss, man, it won't be cheap to fix!
To bust the whole motor like that it was either really abused or it was completely out of tune.
For some reason I have a sneaking suspicion that Kleemann has some really poorly tuned ecu's running around as all 3 seem to be motors damaged by really bad detonation. One one car kleemann told the owner that the knocking sound (detonation) was just the cat rattling around under load. Well couple months later that motor had a cracked piston caused by really bad detonation. The heads on that car were also shot. Seals were toast and the heads needed machining.
Have your shop look more closely at this issue. Do a compression test on all 8 cyl. and have the head inspected. Re-building the head and replacing the one bad piston could be a whole lot less expensive than re-building the whole car. It would be really odd if all 8 pistons were bad. Piston 5 is normally the first rod to crack.
In a couple cases people suspected a bent rod on some motor (due to really low compression in one cyl) but both motors had cracked pistons -- cracked between the two piston rings. This crack caused the low compression and not a bent rod.
Modded cars are amazingly fast when tuned well but sometimes things go wrong. This looks like a 30k+ repair bill!
Was this issue maily AFTER the recall? This could be the issue.
I just cant see a dealership putting such info in writing as it would almost for sure cost them a whole lot of money if the factory ever found out. In that case its not MB's fault. The buck would stop at the shop who inspected and certified the car.
Looking on the bright side ... you have a decent opportunity here - assuming you want to do this - of getting stuck into that motor ripping it up and rebuilding it a-la finny and make a real monster... there is one caveat on this and that is you need to ensure the heads, block and crank is OK. If they are fine: Happy Days!! and off to tool town you go... more than this and the bill climbs pretty quickly ...
I would still like to know exactly what wrong with the car... as a disentigrated fuel pump does not cut it for me ... is there no secondary filter btwn the pump and the injectors? If parts of the pump got into the motor (would injectors not clog up first?) the sleves are going to be toast. Also I can't see how they can say rods are bent without opening here up completely. Cracked pistons fine any scope can show you that but rods ???
You probably need to get it running agn to get a decent value out of it and since you going to be ripping the motor up may as well go to town I say if you gonna keep her.
http://www.mymbonline.com/forum/view...?p=71101#71101
I cannot seem to connect to that link.
The car did not have any issues with the fuel pump. The pulled the pistons and there are five that are bad. It looks like the rods are fine.
Good luck with the car. I dont know what I would do if that were my car. There are a lot of options but none seem that great.
Does your insurance cover motor damage? Maybe a claim on your insurance would be better as they would just pay for an entire new MB crate motor instead of a re-build job that could go wrong down the road.
