Replacing the fan
The manufacturer claims that this fan flows 30% more air and is quieter than most fans.
Perma-Cool 85180 - Perma-Cool Hi-Performance Stainless Steel Flex Fan
Perma-Cool's Best Flex Fan!
Extra wide stainless steel blades with exclusive accelerated pitch angle flows substantially more air at all RPM ranges. The power saving, lightweight construction is available in standard or reverse rotation to fit many vehicles. Ideal for applications where additional cooling is needed, such as vehicles with turbos or superchargers as well as full size trucks and vehicles used for towing.
The stock fan (with the -10C fan mod that I told you guys about) + the PTE 160STAT already puts the car below 80C in HOT HOT WEATHER..
We dont have a problem cooling the engine temps down and that fan does absolutely nothing to help cool the intercooler circuit..
Put your efforts somewhere else..
My $0.02.
My $0.02.
In addition to constant low rpm air flow in traffic, the other item I was chasing was increasing the engine load at low rpm and thereby create a situation to cause the SC to be engaged sooner. Flex fans do cause a noticable drag at low rpm (but "flex out" at high rpm). I've ditched that notion though after the RT ECU flash and other items that got me to where I wanted with my car setup.
