E63 fog light
Old Aug 14, 2007 | 03:29 PM
Ben's Avatar
Ben
E63
E63 fog light
I just noticed my passenger side fog light glass cover cracked but is still functional. Anyone replace the fog light assembly/fixture? How difficult would it be for a do-it-yourself?
The fixture costs ~$200 from the dealer. Not sure what the install will cost.
Thanks for any information/input.
Old Aug 14, 2007 | 03:38 PM
MiamiAMG's Avatar
C63
Isn't that covered under warranty?
Old Aug 14, 2007 | 04:09 PM
Ben's Avatar
Ben
E63
I wish it was. The lens is clearly cracked from a rock.
Old Aug 14, 2007 | 06:10 PM
Bluemax's Avatar
15 S550 Daily 96 Dodge Viper GTS
Talking
I lost one of mine the first week i had the 63. I had them replace it when the first oil change came up. They only charged me for the light assembly and no labor. I think it ran about 200.00 for the light.
Old Mar 5, 2009 | 11:06 PM
E63POWER's Avatar
07 E63 P30,08 997 911 TT 700EVT,07 Audi Q7 S-line 4.2
just happened to mee
Old Mar 5, 2009 | 11:18 PM
Fr33kn63's Avatar
E63 AMG
happened to me too, but had a slight fender bender soon after and ended up throwing it on the insurance
Old Mar 6, 2009 | 08:51 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
TO answer the question:
It is easy to replace. You will remove the 3 screws that hold the plastic "mesh" surround from the foglight and pull it straight off. You will then remove the 4 screws that hold the foglight in and pull it straight out, unplug the cable from the bulb, then reverse the procedure to put it back in.
Simple hand tools and it shouldn't take more than 10 minutes.
A tip to keep them from cracking in the future is to have them covered with clear-bra. The only downside to this is that if you use the fogs all the time (which you shouldn't), the clear-bra material can curl. If you don't, it will save the lights from 99% of rocks that can crack them.
Old Jul 29, 2009 | 12:01 AM
et63's Avatar
commuter
I have a cracked one also. Has anyone replaced their E63 fog light(s) with an aftermarket brand? If yes which brand?
I can across this pair with Hella bulbs on ebay for $80.85 shipped.
http://cgi.ebay.com/ebaymotors/03-08...Q5fAccessories
Wondering if anyone else picked this set up before. Good/no good?
