Polk Audio sub install
Old Aug 14, 2007 | 09:52 PM
jangy's Avatar
2015 S212
Hehe, Jangy does his own install. Actually, I am waiting on my Reus drivers to arrive, so I rigged up this old box in the mean time. I don't have all the settings right, but the old driver still sounds pretty good.
Attached Thumbnails Polk Audio sub install-sub-2-.jpg   Polk Audio sub install-sub-6-.jpg   Polk Audio sub install-sub-7-.jpg
Old Aug 14, 2007 | 10:01 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Jangy, do you mind giving me some detailed info on how you hooked it up? I have all the components, just dont know where to get the leads, and signal for the amp.
-Walter
Old Aug 14, 2007 | 10:13 PM
jangy's Avatar
2015 S212
I'd be happy to investigate and let you know. I used the power and input disconnects that Reus Setup. It was too easy. Starting fresh, you will need to do some wiring. I believe most audio shops will do this type of wiring for about $100. I know the power is straigt from the rear battery.
Old Aug 14, 2007 | 11:29 PM
Torquey55's Avatar
2006 E55
Bring that beast to FL after its "Reus"ified. We can go bangin' ghetto style together.
Please post pics of the install mang!
I'm still biased to JL Audio.
Old Aug 14, 2007 | 11:35 PM
jangy's Avatar
2015 S212
I already have the Reus setup. I just blew the driver and am getting some replacements. It is defintely the most stealth setup, but i love the JL Audios, too.
Old Aug 14, 2007 | 11:38 PM
mprsev's Avatar
2024 G63, 2021 X7M50i
Hey Jangy are you upgrading your Reus subs? I thought you went with the Reus two 10" sub enclosure, which I believe is the same one I went with?
I am interested to know if Rick has improved his subs?
Old Aug 14, 2007 | 11:44 PM
jangy's Avatar
2015 S212
I did go with the 2 tens, BUT I chose the drivers with the best dynamic range. Instead, I listen mostly to hip hop and wanted something with more hit than just bass. Turning the gains up made the speakers blow, so I am getting new ones. I am choosing the "hip" hop version, but that may not be the optimal choice for all. The range on the first set was really nice. These style are more on / off. Just let Rick know what you listen to and he will hook it up. price is a little more for these subs, though. Considering everything, I would think he would upgrade you for free as long as you were in the initial group buy.
Old Aug 15, 2007 | 05:13 PM
Torquey55's Avatar
2006 E55
I would love an opportunity to hear a Reus system. Any FL members here that can help me out?
I envy you jangy.
You are God-like amongst us E55 common folk.
Old Aug 15, 2007 | 06:19 PM
jangy's Avatar
2015 S212
I envy you jangy.
I'm as common as it gets. Hehe! It was funny. i had a cracked windsheild and took it into the dealer for replacement. The SA calls me back and says, "do you have some kind of thing wired in here?" I asked why and he said there is a bunch of wires behind the windsheild. I told him about the Reus system and he verified that is what it was. It turns out that it was the wires running to the 2 center channel tweeters in the mirror. The work is really stealth.
On another note, does anyone know what the settings should be on a 2 channel amp that is being used to run this Polk? I have no clue how to tune it: Frequency, EQ, Gain 1, Gain 2. Any help??
Old Aug 15, 2007 | 08:50 PM
sdsilverm3's Avatar
Did you turn up the gain or did Reus do that on the Reus subs?
Old Aug 15, 2007 | 09:46 PM
jangy's Avatar
2015 S212
Reus did at my request. I'm sort of torn. I love the hip hop setup when I am listening to it, but I love the full range at other times. Maybe I need two types? I dunno. They are replacing them with some that "hit" more.
Old Aug 15, 2007 | 11:17 PM
mprsev's Avatar
Interesting. Please keep us informed as to the sound quality, difference, etc. with the new subs.
I spoke to Rick a month ago and he mentioned the option of upgraded door speakers as well. I am very happy with the system but curiousity drives me to see how much better it can get.
Old Aug 16, 2007 | 12:28 AM
jangy's Avatar
2015 S212
Mine has the upgraded door speakers with the little boxes (I think the have mids in them), 2 center channels, and 2 10" subs. You can always go more, but the next step up is about $1000 more.
I hope to have the replacements in thsi week, so then I can re-install the box and go stealth again.
Old Aug 16, 2007 | 03:12 AM
korveine's Avatar
2005 E55
Jangy, I also have the Reus system from the group buy you set up. Thanks again BTW! I noticed that you have the cargo tray in pictures above. Does your stealth setup have the Reus subs sectioned off with a board and you cannot use the cargo tray? I'd like to put my cargo tray back in.
Old Aug 16, 2007 | 10:38 AM
jangy's Avatar
2015 S212
I just took out the box and put the tray back in and the box sits right in. It is really easy. Catch is that you can not pull out the cargo tray when the subs are mounted in place, since so much weight is on it.It will still lift up with the hatch door to the spare.
