Installed Johnson CM30 pump
Old 08-17-2007, 11:35 AM
StevesAMG's Avatar
03' E55, 06' Kawasaki ZX-10R
I got the pump in yesterday and got under the car to see how difficult the install would be. It was remarkably simple. The most difficult part was just removing the hoses and getting coolant all over you..However, the stock hoses clamped right up to the Johnson with no problem. I was even able to put the smaller Johnson pump in the same housing as the stock pump with just wrapping some extra rubber around it. The last thing to do was i just crimped the stock wires and mated them with the bare wires for the Johnson pump. The whole install took less than 45 minutes including removing the bottom plastic cover of the front of the car.
1st impressions:
I tried to run the car as hard as possible to see if I could get the blower to shut off. I couldn't run it all that hard but at the same time the power was always there.
I was more concerned with the fact that it would keep the air intake temperatures lower than normal, which it seemed to do. The car lights the tires up in 1st gear at will and seems to have more ***** for sure.
I have just one question forthose who may know.....When I removed the old pump, I lost what seemed to be about a quart of coolant(i was expecting all of it to come out). So I just added about that much to the reservior.....Is it that simple or is there a need to purge the system or what? If so, what should I do to it? Thanks, Steve
Old 08-17-2007, 12:38 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Best case scenario, you should have flushed the system with new coolant to get out air bubbles that can get trapped in er. That can be a pain hooking up the hoses and having someone pour in fluid etc.
VRUS mentioned a few guys have had that problem. Keep checking that res for a week or so to make sure.
Real test is the datalogger and checking those IAT's.
Sounds like a pretty easy install, great job!
Old 08-17-2007, 12:59 PM
ItalianStallion's Avatar
R35 GT-R, EvoX
You said your car feels like it has more *****...did you actually see some power gains? I didn't think this mod netted anything more than having the supercharger run much longer under high loads.
Thanks and congratulations on the mod, the insufficient cooling system is the one complaint I had about the 55's.
Old 08-17-2007, 01:13 PM
StevesAMG's Avatar
The way I understand it is that with a faulty IC pump....it doesnt necesarily mean that the supercharger will shut off at high IAT's and otherwise the car runs 100%.....
The supercharger shutting off is the EXTREME symptom of ultra high IAT's. However, it can still be on, however since the IAT is so high, you are losing power anyway....
I am thinking now that if cooling the temps down this much makes a difference, then perhaps i should install a larger heat exchanger also to get them down even more....the install seems simple. thoughts?
Old 08-17-2007, 02:41 PM
phatmitzu's Avatar
2005 E55
Awesome!
The Johnson CM30 pump looks small dont it.
Old 08-17-2007, 03:22 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
a larger heat exhcanger will difinitely help but what you could do that might give a noticable benefit and wouldn't cost more than a few dollars is simply separate the i/c and engine cooling circuits. it's as simple as removing the "t" fitting and reconnecting the hoses together. it would be interesting to see how much benefit is available with the oem heat exchanger if it's on it's own circuit.
Old 08-18-2007, 07:18 PM
SteveFox's Avatar
Bentley Flying Spur, CL550
Could you elaborate a little more on this.
Old 08-18-2007, 08:46 PM
chiromikey's Avatar
the engine coolant and i/c coolant mix and should be separated for better efficiency...but nevermind, i forgot that he would also need to add a reservoir so it's not quite as simple as i stated. regardless, it would still be fairly cheap and easy so it might be worth some invetigation.
Old 08-18-2007, 11:36 PM
Ted Baldwin's Avatar
300ce
.............the CM30 is $150 more expensive than CM090. What is the difference? I mean in concrete terms. Is the flow rate the same? Longevity the same?
Ted
Old 08-19-2007, 12:43 AM
phatmitzu's Avatar
2005 E55
Ted
Wait, are we talking about the same Johnson CM30? From Steve's previous post, this eBay seller is selling it for only $69.
http://cgi.ebay.com/ebaymotors/Magne...mZ200141033580
Old 08-19-2007, 05:41 AM
Rafal's Avatar
2017 S63 Coupe Iridium Silver
We must be getting different SC pump specs in Australia because of our hot climate.
I can run my car around the circuit track all day at WOT at 90F and have never ever seen my SC shut down! Can the guys from the Persian Gulf comment here?
Old 08-19-2007, 01:47 PM
narf's Avatar
W211 E55 AMG
haha... i can't believe that the guys in the US are getting substandard components...
someone should investigate this...
i too have run my car at WOT at high and humid temps and expected a shutdown from all the posts here, but nothing has happened...
(my car was built, delivered, and sold in germany)
Old 08-19-2007, 03:56 PM
300ce
.................yes that is the same pump. No one wants to answer if this pump is any different from the CM090 in terms of capability
...........As for US vs Australia, I think the pump is the same bosch oem pump. People in the Us change their pumps for two reasons. First is if the pump fails. Second reason is if you have a larger crank pulley adding more boost and generating more heat. I have never been convinced that a higher flow rate pump is better, but I who knows.
Ted
Old 08-19-2007, 04:33 PM
Jrocket's Avatar
E55
U.S. or Euro cars all use the same pump,over 13 different models use this same pump,including the SLR.
Old 08-19-2007, 04:34 PM
chiromikey's Avatar
Ted
there is no cmo90. the co90 and cm90 flow 90lpm but the cm90 is significantly larger and supposedly more durable than the discontinued co90. both 90 series pumps require 1.5" diameter inlet lines to prevent cavitation and pump damage so running new lines must be considered. because of it's size, possible cutting of brackets and new mounting hardware is also needed.
the cm30 flows 30lpm, around twice the oem bosch unit. the cm30 is rated for the same life hours as the new cm90 so it is just as durable. it's MUCH smaller than the cm90 (even smaller than the oem pump) and because of this doesn't require special mounting, or cutting of stock brackets. the cm30 inlet/outlet is nearly identical to stock so there is no need to replace any lines with a larger diameter and you won't have to worry about cavitation.
Old 08-19-2007, 07:20 PM
300ce
............thanks for the explanation. I actually just saw this link as well
http://www.johnson-pump.com/JPMarine...ion/index.html
Ted
Old 08-20-2007, 03:57 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, LRD4 HSE, R107 280SL
The difference btw the pumps' performance are :-
The CM90 flows 90l/min at 0.25 bar..
The CO90 flows 90l/min at 0.15 bar..
The CM30 flows 26l/min at 0.1 bar..
Old 08-20-2007, 04:21 PM
rbtronnie5's Avatar
You name it i've had it or got it...
after you posted this...i watched them slowly start to diminish in size available...so i grabbed one. seems like a great deal.
Old 08-20-2007, 07:39 PM
Vadim @ FD's Avatar
S600TT, R350
https://mbworld.org/forums/showthrea...78#post2376178
Here is an install on C32. E55 should be very similar.
Old 08-20-2007, 09:15 PM
TopGun32's Avatar
if somebody has a data logger it would be nice to see the before and after on a E55.
if you are modded with pullies, even better.
I plan to do this mod soon. Next 3 weeks or so.
Old 08-20-2007, 09:29 PM
Vadim @ FD's Avatar
S600TT, R350
Having scanned a lot of cars - 55 data will look very much like 32.
Cars with pulleys are about 25-30F higher under boost and very similar during cruise.
Old 08-21-2007, 12:06 PM
Former Vendor of MBWorld
ChicagoX's Avatar
W211 E55
LOL !
One left after my purchase.
Old 08-21-2007, 01:09 PM
dsc
dsc's Avatar
2004 E55
Ya, I got one too.
What's with buyer "cj-special" getting 5 of them?
Old 08-21-2007, 01:20 PM
rbtronnie5's Avatar
probably someone with a shop who can sell it to a customer for much more...i mean most of us here have to have some sort of business savy to get into these cars
Old 08-21-2007, 01:44 PM
SSM AMG's Avatar
2004 S55 AMG
Just bought the last one. One question for the guys that installed it. Is it louder that the stock one?
Quick Reply: Installed Johnson CM30 pump
