SC Clutch bearing noice!!
Changed SC belt yesterday, noticed some minor noice in the SC bearing. I am thinking of replacing the bearing just in case...
Searched the forum...but could find any info on the bearing...Just info of the C32 bearing.
Does anybody now where to get or any makers partnumber of bearing? Maybe the C32 bearing is same?
The according to the EPC there is no part listing except the whole charger assembly.
Anyway, if the bering or seals go, a small amount of oil will come out of the nose and onto the belt.
The charger blades are independent of this bearing as well so no need to panic about the charger flying apart.
Thanks Finny!
I drive long distances in unpopulated countryside so I wan't to be sure all is ok (cold as h..ll here...-40 C was worst last winter...upside is no heat soak problems most of the year!!... but no traction either...)
I suspect bearing to be just behind clutch, probably only have to loosen nut in front of clutch and slide it all of. Thats the way the 32:s SC is anyway.
I'll pull it apart to get bearing number.
