How come their are no K&N type air intakes available?
Why can't we do this on the E55? Is their just no aftermarket support for a good "affordable" mod? The intake I put on the pathfinder might even fit on the E55 (of course i'd need two of them), I almost wish I tried it before doing the install. In addition to getting a really good bang for the buck the truck sounds mean now.
That's why the VRUS insulated tube system is the only worthwhile upgrade to the air intakes. Don't waste your money trying to figure out how to put a couple of K&N cone filters under the hood - they're such a joke.
And they really do sound great, no drone like an exhaust can give you, just high RPM screaming.
Agreed, back about 5 years ago I dyno tested a intake before and after on a 2002 maxima. The Intake added 12 WHP. So I agree, these things are no joke, their a good bang for the buck.
The air box is a good but the free flow cone in front of the radiator is better.
In between is the renntech air box. You do what can fit in the engine compartment.
Then it would be sucking hot air from the engine compartment.There is no room for one in front of the radiator.Even if there was room,then its going to be sucking in water if it rains.It has to be shielded from water yet be in the direct path of cold air,thats going to be hard.
WTF>>>"2004 E55 Loaded, Ran 12.455 @ 111.84 MPH Stock (1.84 60'). ASP pulley & Evo Sport Headers installed, ran 12.6 at the track?."<<<
Your mods are making your E slower.
As for getting water on the filter in front of the radiator. I don't believe that would be a problem. If you have ever opened your hood after driving in the rain it stays perfectly dry in their. If anything their would be less of a chance of water getting in over the stock unit, it's sucking air being ramed into the air scoups.
Good luck and keep us posted.
Filter behind radiator,pulling in hot air from engine....worse than stock.
If I suggested that the filter should go between the grill and radiator I did not intend to. I believe the best position would be behind the radiator, in the engine bay, right where the oem CA scoops reside. IMO they would not get wet, seeing that the CA scoups are sucking the same air in and their is no wetness problem on the oem setup, atleast to my knowledge. The hoter air would of course be a issue, I agree with that point. With a well designed set up, a scoop could feed cold air into the filters. R&D would be pricey, everyone seems fine with out this option, I think it is unfortunate.
While there are cone filter based intake kits of all varieties, all of them seemed to produce positive dyno results. However, that was often on a dyno, hood open and big air fans creating air movement into the engine bay. The general consensus with the VW community was that C.A.I. were the best. Now don't get a Cold Air Intake kit confused with a standard intake kit. The C.A.I. kits like the one that I had on my VR6 had an extended multi-piece carbon fibre intake tube that exited the engine bay into the front bumper ahead of the front drivers side wheel. A previous Neuspeed kit that I had on another VW simply had the K&N cone in place of the original airbox. It seemed to work (well it sounded great) but when idling, the cone was saturated in heat.
With regards to Porsches, K&N cones inside the engine bay were somewhat rare, this despite the fact the rear engined 911's engine is fairly open to the elements (vented rear spoilers directly above). However, there are several aftermarket carbon fibre airboxes available for the many generations of the 911. A common dyno proven mod to the 70's and 80's 911s was to simply install a K&N panel filter and drill large holes into the top side of the airbox directly beneath the vented spoiler.
I think it would be safe to say that all intake kits produce power when you're at highway speeds and a lot of air is being drawn in/out of the engine bay. On the other hand, if you're staging at your local 1/4 mile and you've been sitting there waiting for the lights to go green, the air under your hood is pretty toasty and you might see a drop in power.
Anyway, that's just my 2 cents.
I agree with you. i think a much cheaper and more open system can be made by introducing cone filters. Any bay can be ducted to bring in the right air. I've done F.I.P.K.s to many cars and things like water have to be taken into consideration, but are rarely stoppers. The main gate is usually how much time you are willing to develop a sealed area for air accumulation.
