Everything you Love and Hate about
Old Sep 9, 2007 | 11:12 AM
  #126
rflow306's Avatar
2005 E 55
Originally Posted by enzom
It is like a five hour drive.
I don't go see my mother-in-law down the shore because the 1.5 hour trip makes me nuts. If I take this trip just to race, I am done for. You guys understand, no?
That's no excuse brother it's a 16+ hour drive for me the only difference is my mother-in law already hates me.
Old Sep 9, 2007 | 12:53 PM
  #127
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
That's dedication to the sport. Enzom- are you listening?
Old Sep 9, 2007 | 01:11 PM
  #128
juicee63's Avatar
2011 twin turboed prius
You need to be more careful about checking your facts -
I ran 11.9's all day long at Atco with a BEST DA of positve 778 feet. And it wasn't on 1.6 60' times, nor did I remove weight. So you are dead wrong there. (Can you admit that much?)
http://www.dragtimes.com/2005-Merced...ecs-10571.html
But I guess if your calculator tells me that it was not possible for me to run 11.901, 11.904 etc. with a DA of plus 778, I will call the Atco track and tell them that they need to check their equipment.
Key here is I ACTUALLY ran those runs. So it isn't what a calculator says I should have run - but what I ran.
I do not recall the DA at E-town that day (3/31), but it was definitely NOT minus 1000 ft. I remember hearing that it was plus 200 ft., but I have e-mails out to two of my friends that were at the Corvette Challenge that day for an answer.
If I come back and tell you that they have confirmed that it was plus 200 ft., will you start to realize that your calculator, and/or your method of collecting data from places other than the track, yield incorrect results? Or are you going to continue to insist that I am wrong?
EDIT - Out of curiosity, what do your off-track sources tell you the weather was when I made my runs at Atco? How far off of 778 ft. is it? Wouldn't that be a fair way of comparing the extent of the accuracy/inaccuracy of your date-collection methods?
Thanks Enzom,
I willl check
Here is your 3 runs under FULL correction , your SC requires me to do more work but you can see they correction factor is only as good as the data you input. Your DA is slightly different but it is negligible. I previously corrected your slip and it matches up nicely with these runs, you have some consitant times so this actually is a great tool for you to measure which run is best as if they all happened same time same day same car same driver. Only you know what was diffferent about your car, fuel,tires,weight, modes..
here are the three runs the results are linear and the correction is very minute.
slip 1
The closest weather results for 11/17/2006 at 02:10 pm
Time recorded 1:54 PM
Temperature °F 62.1
Dew Point °F 41.0
Altimeter Setting 29.77 Inches Mercury
Absolute Pressure: 29.74 Inches
Density Altitude: 535.5 feet
Track Elelvation: 33 feet
UnCorrected ET:
11.901 (sec) @ 117.23 (MPH)
Corrected ET to Sea Level:
11.834 (sec) @ 117.905 (MPH)
I checked weather on both sides of the slip and DA was dropping in the area from 1pm-3pm, so the 778 reading differs . We can use that # if you prefer or I can convert this run to 778?
Run #2
The closest weather results for 11/17/2006 at 02:02 pm
Temperature °F 62.1
Dew Point °F 41.0
UnCorrected ET:
11.904 (sec) @ 117.01 (MPH)BEST ET
11.837 (sec) @ 117.684 (MPH)
The runs are so close together that you likely just correct the best run and compare that to the run that occured on a different day or hours prior or after. You only need to do this if the DA has changed by a margin of significance.
Run #3
The closest weather results for 11/17/2006 at 01:16 pm
Time recorded 12:54 PM
Temperature °F 62.1
Dew Point °F 41.0
Altimeter Setting 29.76 Inches Mercury
Absolute Pressure: 29.73 Inches
Density Altitude: 546.9 feet
UnCorrected ET:
11.913 (sec) @ 117.59 (MPH)
11.845 (sec) @ 118.281 (MPH BEST TRAP SPEED
So you have essentially the same DA on this day on all three of your runs comparing all three lets correct the best run and take it down to the negative DA say of -1000 and see what your car would have done had it run
http://www.dragtimes.com/2005-Merced...ecs-11697.html
I previously corrected this time so I will use the full correction so our data is consistant. If we want more precise #s we must take .50 of the correction factor, but taking 100% will still show you which run is FASTEST if all the runs happened at zero feet.
Here is your run from March 31st, the weather info is printed on the slip
The closest weather results for 03/31/2007 at 09:01 am
Time recorded 8:55 AM
Temperature °F 46.4
Dew Point °F 21.2
Altimeter Setting 30.25 Inches Mercury
Absolute Pressure: 30.17 Inches
Density Altitude: -1054.7 feet
Track Elelvation: 86 feet
UnCorrected ET:
11.850 (sec) @ 118.17 (MPH)
11.981 (sec) @ 116.83 (MPH)
Run #2 weather info on slip matches data collected from weather station.
The closest weather results for 03/31/2007 at 10:01 am
Time recorded 9:55 AM
Temperature °F 48.2
Dew Point °F 19.4
Altimeter Setting 30.27 Inches Mercury
Absolute Pressure: 30.19 Inches
Density Altitude: -959 feet
UnCorrected ET:
11.892 (sec) @ 117.72 (MPH)
12.012 (sec) @ 116.506 (MPH)
Here is where the comparison gets interesting..
We now have all the runs at SAE zero feet.
Your runs at ATCO are better lets take your best run and see what you would have done at Englishtown at -1000 DA.
Here is your run from ATCO
UnCorrected ET:
Im going to take it down to -1000 DA or more specifically -1054 the same DA you had on March 31st 2007
E.T. 11.901 (sec)
Trap Speed 117.23 (mph)
Measured DA 535.5 (feet)
Corrected to -1054(feet) DA
Corrected ET 11.704 (sec)
Corrected Trap Speed 119.256 (mph)
Your runs at ATCO were stronger than your runs at Englishtown, only you know what was different about the car, maybe you just drove better.(60 ft times were better) This is absolute fact, not speculation, the numbers came from your slips and were simply all converted to the same standard(0 feet) geopotential altitude. I took all your runs and put them on the same track same day same driver same car.his is merely one more tool you can use to compare your runs on different times, different days , different tracks.
I could put your times at any standard the calculation is composed of known constants in the atmosphere. I could take all your runs and put them at 5000 feet, whatever. I use this to compare my runs to others.
You have a fast car and your runs are very consistant. Your car will run sub 12 seconds in conditions under 1000 ft. So a DA over 1000 ft would IMO be a necessary notation. Obviously IMO a negative DA should also be noted because the "fast time" was aided by atmospheric condition" more than ecu tune , traction, etc.. Your driving was better at ATCO by a slight margin, it was the "great air" that got you the 11.85
You are correct this is less accurate as a prediction of future runs, it is only accurate 100% at taking several runs and putting them at zero feet. certainly does not mean you will ever run what the calc says. BUT it does tell you with 100% certainty which run is faster when placed at a standard.
The weather info you question is printed on your timeslip? You have a recorded barometric pressure and temp and it matches my calculator so the DA at englishtown as measured from your slip was 900-1100 feet below sea level.This would have been the 1 hour previous to your run and one hour after. The Air on March 31 2007 never got to 200ft it was negative the entire day by 900-1100 feet. Temp was 46-51 degrees and would have to of gotten to 62 on the track , its more likely that who ever told you 200 ft had a bad reading. Unless the temp at the track was 12 degrees higher than the weather station. Best ET uncorrected and corrected,
You had a higher trap on the other run,
better ET on this one
Man you have a fast flippin car
to me your best run is at Atco
UnCorrected ET:
And is truly AMAZING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! stock this BLOWS my
mind.
Old Sep 9, 2007 | 02:08 PM
  #129
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Originally Posted by MB_Forever
I'm down with that....
Lets also try to organize an event at Famoso in the winter. The weather gets really cold there and should be awsome for drag racing......
Adam, are you reading this?
Sacramento raceway is closed for any private event this year.
On Saturday, it's $5000 to rent the track + expenses.
On Sunday, it's $3500 to rent the track + expenses.
Jennifer has kindly suggested that those interested in running should participate in the CMI sport Compacts September 30th or January 13th 2008. Cost is much cheaper because CMI pays all track rental and expenses.
According to her,
"Your group would just pay the $45 race fee or $10 spectator fee and CMI provides you with your own lane of racing so you can race just your group."
Hope this helps.
Adam
Old Sep 9, 2007 | 02:36 PM
  #130
Jrocket's Avatar
E55
According to her,
Hope this helps.
Adam
While you wait for 300+ Hondas trying to figure out how to line up,do a burn out and then break the tranny 5ft out...then wait for a tow off the track and thats only if they havent oiled down the entire lane first! Uh,no thanks on the import days.Plus I cant understand what they're saying half the time anyway...lol
3500 for a Sunday isnt bad! Get 15-20 people and split the cost,Im ready for that.Track all to yourself and no fart can noise,sounds good to me.
Old Sep 9, 2007 | 04:54 PM
  #131
Jrocket's Avatar
E55
Nice find, I'm definately going to sign up.....
Cool! I just got an e-mail confirming 20 spots still open and they are indeed running both lanes.
Old Sep 9, 2007 | 07:39 PM
  #132
It's $3500 + expenses.......
Here's what she said
I would need to know how many cars, spectators, and speed of fastest car to accurately quote you a rental price. We do not have any available dates in 2007. You can put together a rental proposal for next year. Track rental starts at $3500 for Sundays plus expenes(insurance, employees, ambulance, VHT, clean up) and goes to $5,000 for Saturdays plus expenses.
Old Sep 9, 2007 | 10:33 PM
  #133
juicee63's Avatar
TED BALDWIN
You have been critical of the correction, noting DA from the beginning. You have never truly offered anything of substance to the argument against.
You run what you run, man I hope next time I go to SAC i have a tail wind and a -1000 ft DA, I will run a 12.1 and you will see no talk of DA. Comon guy seriously , ok now comeback with the runner stuff , Hey does that DA look familiar?
Funny your only slip on dragtimes shows your car blistering down the 1/4 mile in 11.9 @116.X, I know why you do not correct or mention DA easier to just list slips of fast runs. What was the DA during your run in November 2005 at 11:36 PM at the Atlanta Dragway?
This is where my correction calc comes from, read it maybe you will better understand the calculation, I suppose this is witch craft?
http://ntrs.nasa.gov/archive/nasa/ca...1977009539.pdf
Old Sep 9, 2007 | 11:09 PM
  #134
sack5000's Avatar
2015 AMG C63 S
Originally Posted by juicee63
TED BALDWIN
+1 go Juicee go
Old Sep 10, 2007 | 12:02 AM
  #135
juicee63's Avatar
OMG MY DRAMS HAVE COME TRUE.. I ILL BE AT EVERYONE OF THOSE!!!!!!!
OK IM IN!!!!!!! Lets go Mr. Rocket.
MBFOREVER?
SAM?
Old Sep 10, 2007 | 12:04 AM
  #136
Jrocket's Avatar
E55
MBFOREVER?
SAM?
You already sign up and pay? You 100% going?
Old Sep 10, 2007 | 12:52 AM
  #137
juicee63's Avatar
yep, paid and emailed em deets..
This is a great track but 850 feet, we need 60 degrees 8am run!!
Lotsa mustangs, you can take down the Z and let me handle the Camaros
Old Sep 10, 2007 | 12:58 AM
  #138
Jrocket's Avatar
E55
Actually its a little over 1100ft...1121 to be exact and you'll swear it looks like it runs way up hill.The track officials say no,but we checked it with a hand held gps and it does indeed run up hill.
Now that I think about it we checked and it was 1154ft or so.
Old Sep 10, 2007 | 01:08 AM
  #139
juicee63's Avatar
Oh good we can test our NEW WEATHERSTATION.
oh well , more corrected times
Traction? this should be better than LACR?
Old Sep 10, 2007 | 01:14 AM
  #140
Josh u driving to MIR??
Old Sep 10, 2007 | 01:15 AM
  #141
Jrocket's Avatar
E55
Yes this track does hook better than LACR.One good thing is the amount of cars attending and we get both lanes to run.Im predicting some fast cars to be there,meaning big tire cars and alot of vht and rubber to be laid down.We need cool temps,warm track surface to the 330 mark and no wind!
Old Sep 10, 2007 | 01:17 AM
  #142
Jrocket's Avatar
E55
No,he talking about his deal I just found...
http://alternativemotoring.com/index.html
Old Sep 10, 2007 | 01:21 AM
  #143
juicee63's Avatar
Dam I want to go so bad...cannot really get away for long enough..But I will be attending SACRAMENTO soon to race my favorite modded E55 hey wheres Denny's LOL
Old Sep 10, 2007 | 01:29 AM
  #144
Thanks for the info John.
We are heading up this friday for test and tune. Care to join us? Why don't we tune your car real quick?
Old Sep 10, 2007 | 01:40 AM
  #145
juicee63's Avatar
Friday evening? anything on Sat?
hmmmmmm tempting but I think I gotta work.
Old Sep 10, 2007 | 01:48 AM
  #146
Josh? You Work? I see you 24/7 here?
Old Sep 10, 2007 | 02:02 AM
  #147
ROCKETW19's Avatar
06 EuroElites E55
work is over rated bro!
come on im gonna run on my street tires. should be easy for you to put another voodoo hex on my car and smoke me.
adam any word on the wireing? send me the instructions and ill have it done before friday.
Old Sep 10, 2007 | 02:13 AM
  #148
juicee63's Avatar
you selling your light rims.......
hows the weather up there ..man we gotta do this again soooooon,
Old Sep 10, 2007 | 02:15 AM
  #149
juicee63's Avatar
lol
come to cali bro......that would b serious
Old Sep 10, 2007 | 02:19 AM
  #150
ROCKETW19's Avatar
06 EuroElites E55
yes i think i am! i like speed but just not as much as you and others. i have to have a lil bling in my cars. its slow *** 20s for me but i will look good loosing to faster cars with lighter rims.lol.
weater was crazy hot last week 105 but this week it is already cool by 7oclock we wont have no 60s this week but we will have mid 70s
