O.Z. Ultraleggera HLT Offset Questions Please Help
2013 SL550 2013 M6 f12 2011 X5M
Guys,
Please help me with my wheel fitment offset below![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Does this offset work with the 2007 E63?
20x8.5
Tire Size: 245/35-20
Wheel Offset: 32mm
20x9.5
Tire Size: 275/30-20
Wheel Offset: 36mm
Should the tires be Fr. 245/30-20 and Rr. 275/25-20 for the above.
Would the O.Z. Ultraleggera HLT Offset below work with the 2007 E63 and what should the proper tire size be?
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
thanks for your inputs.
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Guys,
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
thanks for your inputs.![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
Looking at the OZ B2B that we have access to, the wheels should fit on the car. If the fronts dont clear the caliper OZ Supplies a 5mm spacer that will enable sufficient clearance. However it should fit straight on with no spacers required on the front
Guys,
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
Will struggle
I think the 10s on the rear will be very tight ... if you go for a 285 tyre you will have a risk of rubbing ... With a 35 offset vs a 39 stock (9" vs 10") you will extend 17mm. My read is that the offset will be 32, looking at the ozracing website for the 19" HLTs, which will be 20mm wider. This will risk rubbing the fender on the outside of the tyre under full compression.
Read rafal's posts. Good luck.
Guys,
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
20x8.5
Wheel Offset: 32mm
20x9.5
Wheel Offset: 36mm
20x8.5
Wheel Offset: 32mm
20x10
Wheel Offset: 35mm
That the offset on my wheel and I have 10" on 285/25 on rear, no rubbing when lowered either.
E55 AMG
Standard set up is 30 front 39 rear, right?
My 19" are 8.5 ET30 and rear is 9.5 ET31.
Is it not the lower the offset the more it sits out?
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Assuming you have a W211 E55 and it wheel set up is the same as E63 which I sure it is than the stock offset is 18x8.5" 38mm front and 18x9 39mm rear (18x9.5 44mm performance pkg) per owner manual page 440.
E55 AMG
I have two sets of wheels for my E55.
Stock set (AMG type IV)
Front alloy wheels: 18x8" ET30 A2114012602
Rear alloy wheels: 18x9" ET39 A2114012702
Upgrade (AMG type IV 2pc)
Front alloy wheels: 19x8.5" ET30 A2114001202
Rear alloy wheels: 19x9.5" ET31 A2114001402
I am now looking for a lightweight package based on stock sizes with a more aggressive offset...
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
I'm thinking that...
245/30/20 is correct. A 35 might be OK on the "smaller shouldered" brands (Bridgestone or P Zero), and the 30 might be better with Michelins, Toyos...
E55 AMG
