Need help in buying an 03 E55
Other than the IC pump, S/C squeal, and poorly constructed articulating cupholder, my car has been pretty much flawless that I can remember. It was very sluggish for awhile, but that was my fault for not properly cleaning the air filters.
Do any of you buy warranties on electronics, appliances, etc. or is it just these cars.
To the OP, have the tires, brakes, etc. checked by someone during a thorough pre-purchase inspection. Go to your MB dealer and get a list of all services that were performed on the car. If it had any electronic or electric-type problems (radio, seats, windows, sunroof, A/C, etc), then I would agree that a warranty is probably a necessity as any of these problems can cost thousands to fix (same as the E500).
Take the car for a long test drive and really drive it. It should still feel like driving a new or nearly new car. There should be no unusual vibrations, sounds, clanking, etc. You might feel a surge (and possibly hear a squeal) when the car is between 1st and 2nd gear, which is the S/C engaging. This can be somewhat rough and loud in some cars but should be the only unusual part of your drive. With 51k on the odometer, my car is still very tight and rattle free. I have noticed only a very, very slight decline in the way the car rides today compared to when I 1st bought it with 7,000 miles.
Nothing is really cheap to have done to these cars. I have been told that brake pad replacement is a $500-1000 job minimum, tires will run $1,200-1,600 per set with the rears lasting 5-15,000 miles and the fronts lasting 20-30,000 miles. Oil changes will likely set you back $75-150.
If the car does have some warranty on it and the IC pump hasn't been replaced, have them do this for you. Additionally, if you can talk them into it, the updated supercharger clutch really improves the overall driving experience. If still under warranty, the services are included just as your E500 had. Check the dash display to see when the next service is due. If its coming up soon, have them do it before the warrany expires.
If everything checks out with it, enjoy.
