OBDII scanner output to COMMAND Screen?
Old Oct 29, 2007 | 05:10 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Hi there is it not possible to hook up a laptop with a data logger to display gauge/data video to the command display via aux TV input?
The laptop is surely a workable solution...although some effin around when you get it started, power feed etc,etc...
A permenant hardware unit (i.e. a 12v interface module) hooked up in this way would be simply awesome.... This would be ideal no?
There has to be some way of getting the OBDII data to display on the COMMAND screen ........ mbe some secret menu?
Old Oct 30, 2007 | 03:50 PM
Vadim @ FD's Avatar
S600TT, R350
Steve, I looked at doing this way back when I got my C32 with COMMAND. It can be done, you just need to make a custom video converter along some other hardware to read out data. The problem was cost of one-off unit was into $1000s and to mass produce this for MB market would run a lot higher. A laptop with commonly available $300 software is a bit more versatile.
Old Oct 31, 2007 | 04:45 AM
stevebez's Avatar
Laptop and associated gear is already being prepped !!!!
Old Nov 1, 2007 | 11:42 AM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Why not install a low-budget barebones or laptop and interface a TV-Nav-And-Go unit?
Old Nov 1, 2007 | 12:33 PM
stevebez's Avatar
Going to fit my v old laptop and plug it into the COMMAND aux tv port in the trunk.
barebones? Sounds like something I need....
Old Nov 1, 2007 | 12:46 PM
ChicagoX's Avatar
W211 E55
Maybe something like this?
http://www.tigerdirect.com/applicati...601&CatId=2846
$150.00
Or this:
$325
or this:
http://cgi.ebay.com/Nano-ITX-TINY-Fa...QQcmdZViewItem
