Thinking e and cls maybe sl too and possibly ml and gl but are c's smaller and s's bigger?
I'm confused on your question. Just to clarify, the E55 and E63 have different FRONT rotors. NOT all 55 front rotors are the same and not all 63 front rotors are the same. It is model specific. The S / CL > E / CLS > Chh
you know the e63 has a 2pc front rotor obviously. is the same rotor used on sl cls ml gl yet a smaller rotor on a c and a larger one on s and cl? or since all amg's get the big brake kit are they all the same? a quick trip to the dealer could answer this with stock #'s just curious if anyone knew here.
thanks
thanks
Quote:
thanks
Originally Posted by dc63er
you know the e63 has a 2pc front rotor obviously. is the same rotor used on sl cls ml gl yet a smaller rotor on a c and a larger one on s and cl? or since all amg's get the big brake kit are they all the same? a quick trip to the dealer could answer this with stock #'s just curious if anyone knew here.thanks
I do not know about the new C or if there is even any longer a C55. The E63 and CLS63 front rotors are identical and use the CLS part number. The S63 and CL63 use a larger one AND they have different calipers.
On the 55s, the C was the only one with smaller ones. The E, CLS, S, SL, and CL were the same.
It would really help if you used proper capitalization and punctuation.
you da man, exactly what i need!!!Originally Posted by jangy
I do not know about the new C or if there is even any longer a C55. The E63 and CLS63 front rotors are identical and use the CLS part number. The S63 and CL63 use a larger one AND they have different calipers.On the 55s, the C was the only one with smaller ones. The E, CLS, S, SL, and CL were the same.
FANTASM: obviously it doesnt or jangy wouldnt have answered my question.
