check engin help
E 63,E55 (gone) E46 ///M ,B5 stage 3 S4 ,E36 ///M , 03 EVO (800 WHP)
check engin help
anyone else experience this?
the car runs fine sometimes and then all of a sudden almost always when the gas gets low it starts to run pig rich and the idle is all over the place like it has a cam in it, also it starts to shake and jump around.
i have the stage 1 and a while back the dealer downloaded some software that said thottle somethingthis is all when i got all my valve cover gasgets changed.
the codes i am gettin are :
*load limit
*idle speed controler inpausable
*charge air pressure sensor
*inlet valve not operating
other than this the car has been perfect im thinkin about sending my computer back to get reprogramed any thoughts? btw i took it to the dealer and they check 100 things and came up with nohing after changing a whole bunch of sensors
*load limit
I had same prob with my cls55. It ended up being a TPS and Vaccum leak around the throttle body.
Listen for a hissing sound around the rear of the drivers side of the engine bay.
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
i had the same exact experience a month ago...i still havent fixed it yet...it would throw check engine light and car started to rough idle(whole car was shaking) and when i punch my car, i would hear weird noise coming from the engine(kinda like whistling sound...)
