My E55 is not running well...
Old Nov 17, 2007 | 04:13 AM
tommy25000's Avatar
2005 E55
I brought it in a couple weeks ago for the IC pump, or so i thought. It had all the signs of a bad IC pump so they replaced it. well It is not fixed. I have a johnson IC pump sitting next to me but shouldn't a brand new IC pump from MB work if that was in-fact the problem? If i go full throttle from about 40 to 120mph after that the car is a dog for 5 to 10 min. I have lost numerous races because of this (inc a crappy 5.0 mustang!) also around 1800 rpm the car seems to miss a step. Its under light acceleration and its almost like the fuel is just cut for a split second. Now yesterday a check engine light came on. Also my transmission like to pound the car forward at goofy times under slight throttle up shifts. I would assume the tranny problem in unrelated to the others. The tranny problem is much more intermittent. What's wrong with my car! I know these cars are very well built... anyone have any ideas?
Old Nov 17, 2007 | 04:45 AM
Acez's Avatar
2001 Kleemann CLK 230K, 2006 CLS 350, GTR R35
maybe you need to send it in for a full diagnosis...it's may not always be the IC pump you know.
Old Nov 17, 2007 | 11:16 AM
Jrocket's Avatar
E55
CEL came on,you have problems.Take it to the dealer.
Old Nov 17, 2007 | 05:13 PM
TopGun32's Avatar
I got my trans and torque converter replaced due to that jerkyness from 1st and 2nd and when slowing down.
its alot better.. but I can still fell some jerkyness when slowing down..
I also got my kompressor clutched replaced..
take it in.. or have someone scan it for you.
Old Nov 17, 2007 | 05:43 PM
areuv's Avatar
2005 E55 drowned/ 2011 CTS-v coupe gone/ 2012 E63 PP,LSD finally here
it's kinda of a good thing the CEL came on, it should be easier to get to the problem now that it has stored a code, first thing get it scanned and see what made the CEL light come on and work from there
Old Nov 21, 2007 | 02:56 AM
tommy25000's Avatar
2005 E55
ok it's at the shop! hope all goes well
Old Nov 21, 2007 | 08:04 AM
E55BKS's Avatar
A slow Tahoe!
Don't let them flash your TCU, they did mine and put it grandpa/comfort mode. The sifting was soft and the car tries to go into third before 15 mph.
Old Jan 10, 2009 | 07:15 PM
Ohbev's Avatar
E55 AMG Kompressor
interesting thread...Any update if the problem was fixed?
