Johnson Pump
Old Dec 18, 2007 | 03:26 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Johnson Pump
Hi Folks:
I've got a brand new Johnson Pump (CO 90 P5-1) still in the box. with adaptors , they bring the 38mm inlets & out lets down to 25mm / 1" . Is this worth asking $100.00 for ?
I quess my eyes were bigger than what I needed. ___PTE___
Old Dec 18, 2007 | 04:27 PM
Timeless's Avatar
2005 E55 ///AMG
Guess the questions is...will it work on my 2005 E55?
Is this the CM90 model? And I think most people get the CM30 model...maybe because it requires less work...dunno.
Don't think I helped at all...but my two cents/questions.
Old Dec 18, 2007 | 06:41 PM
PTE's Avatar
PTE
Johnson Pump
Yes I'll will fit. and you are correct It is not a direct fit. It will need some minor movement for reloction. It did come from my Kleemann kit. It is 26.4 Gpm with the 1" reducers & draws only 7.5 amps .
Old Dec 18, 2007 | 07:25 PM
Tech-Tune's Avatar
2006 CLS55 & 2002 SL55 (R129) Silver Arrow
kleemann kit
Hey Patrick, is your kleemann blower on the car yet?
Old Dec 18, 2007 | 07:52 PM
Jrocket's Avatar
E55
Originally Posted by PTE
Hi Folks:
Its worth more than that.
Old Dec 18, 2007 | 10:38 PM
jangy's Avatar
2015 S212
I'm a bit confused. Is this the CM90? If so, I'll take it for sure. $100 is a sweet deal.
Old Dec 19, 2007 | 07:38 AM
PTE's Avatar
PTE
Johnson Pump Specs
A line of compact magnetic driven centrifugal pumps, CM10 and CM30 and the new as top of the line; CM90, which combine high flow rates with very low electric current consumption, making them ideally suited for circulating fresh water in live fish tanks, heating and cooling systems. C090 with mechanical seal and a motor is designed for continuous operation. Designed for also handling fresh water handling.
So the flow rates are the same , CM types have 2 magnets , 1 on the impeller shaft & 1 on the motor armature shaft. The magnets can slip on start up & under hi load demands. Positive is this type is very quite. Kleemann choose the direct drive CO models and rubber shock mounted it for noise isolation.
Capacity curves for CM10P7-1, CM30P7-1 and C090P5-1 Circulation pump at 20°C/68°F, water
http://www.johnson-pump.com/JPMarine...tion/cmco.html
Hope this helps ___PTE___
