High beam and fog lamp upgrade bulbs
In order to measure actual gains in light output, I relied on a Hoppy Vision 1 Image Processing Headlight Aimer, which provides a very close approximation of actual candela produced. Candela is the base unit of luminous intensity in the International System of Units that is equal to the luminous intensity in a given direction of a source which emits monochromatic radiation of frequency 540 × 1012 hertz and has a radiant intensity in that direction of watt per unit solid angle - in a nutshell, how much light output there is.
So first, I took base light output measurements of the stock high beams and stock fog lamps. The high beams produced 23,000 candela of light:
The low beams produced 2000 candela of light with the standard HB4 bulb:
The replacement H7 bulbs, the Osram Silverstars, are a better version of the Sylvania Silverstars offered for the USA market. I found a set on eBay. They came in this packaging:
Here's a comparison picture of the stock H7 bulb (dark tip), and the Osram H7 (silver tip):
The HIR bulbs were also sourced on eBay and are a 55w bulb, so the current draw is virtually identical to the stock HB4 bulb. The HIR bulb requires a small adjustment to the shape of one of the mounting tabs, and I used a Dremel tool for that purpose. After adjusting the tab, the bulb mounted into the fog lamp perfectly. Here's a photo comparing the bulbs:
The results were even better than I hoped for. The high beam output jumped up to 36,000 candela (from 23,000), a 56.5% increase in light output:
And the fog light output increased to 5,000 candela (from 2,000), a gain in light output of 250%.
Since both of the higher performing replacement bulbs are rated at wattages comparable to the stock wattages, I hope not to run into difficulties I've experienced in the past using higher wattage bulbs which required fuse upgrades and heavier gauge wiring harnesses. Now, I seek the darkness because I can light it up
