E55/E63 Owners with Aftermarket wheels that have HUB RINGS, gotta question?
So after I got fed up with the vibration I had two shops check the car and they both told me the problem is the hub rings are loose.
Tire Rack overnight ships me aluminum rings, again 66MM inside bore with a 73MM outside bore.
So this time around I took this into my own liberty to take measurements.
The aluminum rings are a true 65.88MM bore.
My 2007 E63 has a larger bore.
On the Rear hubs of my E63 the bore measures with a Caliper, note the hubs were clean, no corrosion, i got a measurment of 66.78MM. I measured the OEM rims and got about the same.
On my front hubs there is a step lip. The hub seems to start at a true 66 then 3/4 way it jumps up to 66.78.
So i want to know has anyone measured their hubs or is my car the odd ball of the bunch? I am having a local CNC shop make me custom rings I gave them the OEM wheel and they measured my hubs today.
I am so making the Tire Rack comp me for all this headache.
Tire Rack confirmed they never tested a Mercedes E63 or CLS 63 for wheel fittment and just used the 66MM from the E211 chassis from other cars.
