Brakes and Alignment question
Old Jan 6, 2008 | 09:19 PM
rajTypeS's Avatar
2005 Audi S4
I might be buying a used '06 E55 and I was wondering how much people have paid to get the pads replaced and or rotors, also how much people have paid to do an alignment. Any help would be greatly appreciated. Thanks in advance.
Old Jan 7, 2008 | 12:19 AM
jangy's Avatar
2015 S212
Alignment: $200 at the dealer, but not much they can do. 2000 at a custom shop, buy the will redo all the arms.
Rotors: EVOSport slotted and cross drilled - $1500
Pads: Porterfield RS4 (Street) - $500
Old Jan 7, 2008 | 12:50 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
Alignment is $200 I've been doing it under warranty for the last 6 months that I didn't realize how much it cost?
Old Jan 7, 2008 | 08:37 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
My dealer charges $135 for an "alignment" and then whatever they feel like charging on top of that if they have to do any work. Such as $116 to put in a bolt kit and then anther $100 on top of that for a bolt kit. When I was in last, they tried to charge me to put in a bolt kit that was already on the car! You have to be VERY careful with a lot of these dealer techs as all they are taught is to bring it into MB specs and they don't seem to care about trivial things like evening out the camber left to right.
One interesting thing though, the 2 dealer techs that I have talked to swear that the car does not get hooked to STAR for an alignment anymore as "most of the newer cars and all of the W211 E55s will maintain ride height on the alignment rack with the key on". If this is actually the case, I will be talking it to my alignment guy that knows what he is doing the next time that it is due for one.
OEM front pads are right around $350/set
OEM Front rotors are about $135ea
Brake fluid flush is about $120 and requires STAR so no choice but the dealer for this.
Not sure about labor to do the brakes but I'm sure that most dealers are out of hand.
Old Jan 7, 2008 | 01:46 PM
jangy's Avatar
2015 S212
It is typically $200. Your warranty book says that you get one free alignemnet and wheel balance within the first year.
Old Jan 7, 2008 | 02:45 PM
Yes, Where they scratch all 4 of your wheels and then spray paint the scratches silver! They did this to two of my AMGs on their first warranty alignments and getting new wheels was like pulling teeth.
Now when I go info alignments, I have them mark on the invoice that the wheels are perfect and look at them before I leave the dealer.
Old Jan 7, 2008 | 04:38 PM
rajTypeS's Avatar
2005 Audi S4
thanks so far
Just trying to gauge the additional expenses i may incur after purchasing the car. Are the brakes pretty stiff to begin with? For some reason they felt like they needed an extra push to really get the car to stop, at least compared to my S4 which doesn't require much effort.
Old Jan 7, 2008 | 04:56 PM
The SBC braking system in the E55 is going to fell very different from what you are used to in the S4 so don't let that make you think you need a brake refresh.
However, it is not uncommon to nuke the front brakes in 20-25K intervals.
And you can pay $135-400 for an alignment depending on what the dealer claims they have to do or feels like charging.
How many miles are on the car?
Old Jan 7, 2008 | 05:05 PM
rajTypeS's Avatar
2005 Audi S4
agreed, the braking system is very different which is why I wasn't sure. The car has 30k miles on it right now. When you say nuke the front brakes, do you mean putting in new front brake pads?
Old Jan 7, 2008 | 05:45 PM
User110's Avatar
2003 Cl 500
are the dealer's the only people who can do one? their was a thread about manual alignments being done in Cali, and i wish they were here in Ohio. but someone told me that Conrad's has the newest of the systems for all cars and it would be fine to go their? does that work or should i steer clear of Conrad's?
ALi
Old Jan 7, 2008 | 06:10 PM
MB_Forever's Avatar
Is it one free alignment or multiple free alignments though the first year. I've been having my dealer align the car almost every month since I got it
Old Jan 7, 2008 | 07:15 PM
tthoang1's Avatar
2004 E55 AMG, 2002 Porsche 996 TT, 2004 BMW x5 4.8is, 2004 F360
$125 for my recent alignment after I put on the 20's.
Old Jan 7, 2008 | 07:21 PM
ALi
The issue with needing the dealer was due to the car needing to be hooked to STAR diagnostics to maintain proper ride height on the alignment rack. I have had to separate MB techs tell me that the suspension control modules are now programmed to maintain ride height with the key on so STAR is no longer used for alignments.
I will use a good indy shop for my next one. If you don't go to the dealer, be prepared to run over to one to get an appropriate bolt kit if you need an adjustment.
Old Jan 7, 2008 | 07:25 PM
Wearing both pads & rotors to their wear limit and sometimes cracking in the rotors around the vent holes. If you needed pads, it is worth replacing the rotors as the $270 is not bad for the pair and they do get pretty hammered.
Old Jan 7, 2008 | 07:28 PM
User110's Avatar
2003 Cl 500
great, thank you. can i ask why i would need a bolt kit? and if so, should i only trust a MB tech to do it?
how do i find a Indy shop, how would i go about looking for one of them around my area? or should i just give up lol
ALi
Old Jan 7, 2008 | 07:34 PM
The best way to find a good independent shop is by word of mouth.
The bolt kits allow for a wider range of alignment correction to correct for problems.
Old Jan 9, 2008 | 01:11 PM
david_d23's Avatar
2004 E55
Are replacing the pads/rotors doable for most DIYers? I saw a thread a while ago on replacing the rear pads but have not seen one for the fronts. Does it require hooking up to the STAR machine (whatever the hell that is?!)?
BTW, I have done all of the brake work on my previous vehicles, so I am ok as a DIYer, but this is my first MB.
Old Jan 9, 2008 | 02:10 PM
Should be the same as the back just be 100% sure the SBC is disconnected or it will be a really bad day when the brakes pretension and take your finger off in the middle of the brake job!
Old Jan 9, 2008 | 02:54 PM
BrianS's Avatar
2004 E55 AMG
I haven't done the fronts yet but after inspecting them they look just as easy as the rears. You shouldn't have a problem.
https://mbworld.org/forums/w211-amg/199010-diy-rear-brake-change.html
