08 E63 Leaking Oil?
I have 07 E63 and had same problems.
My SA told me oil pan gasket was defective. Although they first thought that it was transmission gasket. My SA told me that it was very rare problem. I hope this helps.
So our luck must be really bad because this is the second car that is leaking oil.
Formula Mazda, Beast Junior...400HP 135i
All of the 55K's are prone to a tranny leak from an electrical connector on the right of the tranny towards the bell housing. As I understand it, it is a quick and easy fix.
I would think that this would have been fixed on the new tranny so who knows what it will be?
You shouldn't have to tow it if it is only dripping, just make sure your fluid level is okay before you drive it.
I would love to drive it since I haven't driven the car in about a month but it is more than drip. I think steady stream would be a better description hence the need for a tow.
2008 Mercedes Benz E63 AMG, 2017 Porsche Macan S
My car arrives this week, and this problem will be on my radar.
Hope the fix was an easy one for you.
https://mbworld.org/forums/showthrea...t=e63+dipstick
Make sure you tell your SA to look up all the DTB's related to oil, oil leaks, oil consumption. Last thing you need is to have a car you do not fell confident in or comfortable knowing the oil could start leaking. Check underneath and try and pin point exactly where it is leaking.
