Code 3 Performance upgrade HE results...
Old Jan 21, 2008 | 01:16 AM
BenzoBoi's Avatar
Super Moderator
W221
Hello all.
As many of you guys know, the 55k motor is a heat magnet, and it is definitely one of the weak links in the car. I figured I was having the usual "heat" soak problem while stock, I should take care of that issue first before adding even more heat (power) to the motor later down the road.
Brandon @ Code 3 and I had exchanged quite a few emails on his upgraded HE's that he was offering. He told me that on the 2003 W211 55K, he offered the regular upgraded HE and he also offered one with a bigger core. I figured why not and pulled the trigger on the bigger core. Everything went smoothly and I received my core about a week later. While all this was happening, I figured I would also opt for the upgraded Johnson pump. So I had bought it online and had it came right about the same time the HE came in. We set up a time where he came over to my house and both installed it in the garage.
We had also gone out before the install to do some data logging on the stock HE and compare it to the upgraded one later on.
Before:
After the data logging we came back, had it installed and went out again to get the after data. Here it is...
After:
As you can see, there is a world of difference in the IAT's and since then I have never had the SC shut off on me again. I just wanted to post these 2 charts for yall to see and talk about. Big thumbs up to Brian over @ Code 3 Performance.
FYI: My exhaust mod is a resonator delete and borla race muffler.
Old Jan 21, 2008 | 01:31 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
it looks like you were running with a bad i/c pump before the swap so it's not a completely fair comparison against the oem system. regardless, the new set up is working well!
Old Jan 21, 2008 | 11:49 AM
jangy's Avatar
2015 S212
Also, it looks like you were really pushing the car harder in the initial run.
Old Jan 21, 2008 | 01:16 PM
tommy25000's Avatar
2005 E55
lets hear that exhaust!
Old Jan 21, 2008 | 01:21 PM
Vic55's Avatar
Administrator
I agree, need apples to apples Sun.
Old Jan 21, 2008 | 04:22 PM
BenzoBoi's Avatar
Super Moderator
W221
now that you guys mention it...I guess yer all right...Well in the end, it werks...
Jangy on the second run, I wasn't able to really get to speeds because of traffic...
Old Jan 21, 2008 | 04:31 PM
jangy's Avatar
2015 S212
I'm still pretty torn between splitting systems or getting the larger one. The price and install is so simple for me this way. Just dunno. Now that I'm putting out more power, I am sure I will run into heat issues soon.
Old Jan 22, 2008 | 12:52 PM
TopGun32's Avatar
anything past tripple digits will create a spike.. but the recovery time is the key for any FMIC HE.
looks like you were running too hot before the upgrades.. as mentioned, probably a bad pump.
210 ITA's will result in power loss.
But after the upprade.. you can clearly see how the larger unit keeps the ITA's on check.. and even if you decide to run strong.. the power will be there.
Brandon is also working on a split system.
