Revised 2008 EPA MPG #s for 03-06 E55
i know u guys **** money and couldnt care less about MPG , but u can look up any pre -08 car and see the updated figures using the new testing criteria.
03-06 E55: 13 city, 19 hwy, 15 combined.
btw, 07 E63 is rated @ 12 city, 19 hwy, 15 combined. even with NA motor & 7sp
E63 P30, CL500 Sport
Honostly, I don't know how accurate these numbers are? I've never gotten less than 14 mpg driving in city. In general, I average 16 to 17 mpg in city and 20 to 22 mpg on freeway
These cars get pretty bad fuel economy!
If you drive over 80.. MPG is bye bye.. 15 to 17
if you stay around 70.. you should get 18's to 20 after 10 minutes of driving.
also.. reset you MPG reader once you actually start driving.. not when you warm up the car. If you leave the car running idle for a few minutes.. your MPG will read 6 to 8 MPGs.
is the MPG reader accurate the first few minutes you start the car? i get depressed when i start the car after work, I get 6.0MPG!! yeah it's *** cold around here & car's running on winter mix gas, but still..
I have achieved 26mpg on the freeway and 8.0mpg on the drag strip. car is a 15-16 average , but you can do much better. drive in C and put a tennis ball under the accelerator pedal
good point regarding tire pressure; I meant to mention that I tend to err on the high-psi side: I have 4psi more than recommended on the gas refill door placard, typically 40'ish up front and 44 on the rear
