New Bosch IC Pump
06 S55 AMG, 03 SL55 AMG, 02 S430(sold), 05 F150, 06 Ranger, My baby 07 HD Rdking
New Bosch IC Pump
Did anyone hear about the new bosch IC pumps, I was told it's as good as the Johson pump, It's basicaly the same pump the S55 has stock, but made better, to be less faulty, and provide more flow, any Info? I took my car to the dealer, and they said so, also had a bad SC clutch, so they put on a new Super Charger. Do you guys think that will help with heat soak?
06 E55 SOLD, 89 300 SE 375,000 miles
06 e55 wagon
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Agree your dealers must suck. Now as far as your rough supercharger clutch engagement, I get the feeling you do not understand it's function. First of all the clutch is electro magnetic therefore it is either engaged or disengaged, no half in half out slipping or any thing that would equate a smooth transition it is on or off no in-between, so rule out the clutch as your problem. The recall on the early clutches was for a loud chirp that the clutch made nothing more.
Now as I posted earlier if you can't modulate the throttle through the S/C engagement in a smooth fashion then yes you have a problem. Understand that you will always feel the engagement, I can feel it but passengers in the car can't when in normal traffic. Should I decide to go to an instantaneous half throttle from a stop the car will start to accelerate stumbles then solid yellow triangle, smoke and side ways action in the rear. normal.
One Item I called to your attention to is the supercharger bypass valve, I even posted a picture of it. Consider this if the by pass valve is closed the S/C when engaged is in a full load condition drawing may be 25 hp. if the bypass is open the S/C is bypassed and draws maybe 4 hp. So as you accelerate the car the the bypass valve is open, then the electro magnetic clutch engages and the bypass starts to close, load the compressor and create boost. Now if your bypass is stuck closed then you will really feel the loss of power when the clutch engages cause the engine is making maybe 75 hp and then gets hit with a 25 hp supercharger load.
At the end of the day what you complain of is why Mercedes Benz / AMG discontinued the supercharged engines too many complaints. If the dealers service adviser rode with you in the car and you demonstrated the rough engagement and he says it is normal, take your car in 3rd time and if you are still not happy then lemon it, and buy a N/A 63.
Joshd - which dealer? I have had good luck with American Service Center in Arlington. They replaced my IC pump and clutch pack when I complained. Ask for service guy named Eddy Gross
06 e55 wagon
I left the car there for a day, but they claim they were unable to reproduce any problem. At least they washed it when they were done
I also told them that my S/C shuts down after hard usage, hoping that they would check the I/C pump. They actually wrote on my invoice 'the S/C will shut down when it's not needed.' WTF
YachtMaster - I do understand that engagement of the S/C may not ever be perfect due to the sudden drag placed on the motor, but it just doesn't seem right that the car lurches backward violently when it engages.
I hear what you're saying and I think you may be on to something with the bypass valve. The problem is I can't even get the dealer to admit there's any problem so they wont even look at that. They basically have both stonewalled me acting like I'm nuts and they know nothing of any S/C engagement issue or even I/C pump issue with these cars. Their default position seems to be that I'm an idiot and have no clue what I'm talking about (see above comment that they actually wrote on my invoice).
I've tried to modulate the throttle to minimize the issue, but what I've come up with is that I either have to drive all out (meaning the S/C is always engaged), or give almost no throttle at all so that it doesn't even engage. Anything else tends to cause a nasty jerk on engagement that passengers notice and mention to me. Maybe it's not the clutch like you say, but I can't even get past the first step of getting the dealer to admit any problem.
I just want to be able to drive the car somewhat smoothly without constantly worrying about jerking my passengers around in daily driving. It's not really a problem when driving all out so that's the good news ...
Sorry for hijacking the thread ... I'm just jealous that some people seem to be able to get good service and get the obvious known problems fixed while my local dealers just play dumb. Or maybe they're not playing ...
Based on your recommendation in the other thread, I did go to ASC and asked for Eddy. He no longer is an SA, so I talked to him for a while but ended up bringing the car to Gary Burk (his name sign hangs next to Eddy's in the service department).
06 e55 wagon
https://mbworld.org/forums/showthrea...Sprint+Booster
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i have a close friend that is a service manager at hagerstown mercedes. i cannot get my sc clutch replaced even with him as a friend. he says the regional people reject the warranty work payament and put it back on the dealer. i don't know if it is a east coast thing or just the west coast people haven't caught up to the rejecting of the cost from the main office. i too have a rough engagement, but have a larger pulley.
Im in the same boat with the supercharger it emgages rough and chirps to no end. I have the stock pulley I can just imagine what it would be like with the larger pulley. The dealership wanted to replace it but MB would not let them so I got a lawyer and well see what happens.
Will
Will
That's BS, I took mine to the dealer, and they found out that the SC clutch was bad, they replaced the whole super charger, as they said they just don't change the clutch, I don't know where you're from Supr, but mercedes of fremont gave me no grief, and it took them less than 2 day, to do everything, including a new IC pump, thermostates, and etc.
2005 E55 ///AMG
Do you guys think, just put in the Jhonson pump, or should I stick with the new, and supposedvley improved Bosh pump???
Connecticut. I went to Fairfield MB first they said they would take care of it but then said they couldnt do anything for it. They also told me they ran software updates and fixed other warranty issues which they really had not they just lied to me. I took it next to the MB dealer in East Haven and they were nice and did all the warranty work that the first MB dealer claimed they had done but had not. They verified the clutch issue and tried to adjust some shims which they said was supposed to correct the issue but it did not help. The chirp is very loud its downright embarrassing. Even when you slow down to take a turn and then accellerate it chirps I can hear it in the car with the windows up and the radio on. 120K cars should not chirp. So back to the 2nd MB dealer they said MB refuses to authorize a replacement supercharger assembly and their hands are tied. There is nowhere to contact an MB corporate rep so I got a lawyer. Federal law states a car dealer must honor their warranty. My factory warranty expires in a few weeks but I have been going back and forth with this issue for several months I think they think if they run my warranty down then Im out of luck but we'll see what the lawyer can do. I can say this when ever I brought my M5 to bmw for warranty work it was never a problem and I brought a 750 I had bought there a few weeks ago and it had damage to the interior and controls from obvious abuse and there was no questions they just warrantied it all. My S55 looks as new as it did the day it was delivered I cant see how they have the ***** to deny a repair for an obvious problem.
Will
Will
They have been stringing me along for a few months on this stating that MB is "reviewing it" but they are really trying to run down my warranty. I know a guy at MB white plains NY and he said they would not let him do anything for it either.
Will
Will
SL 65 AMG and E63s AMG
I took my car for 48000 mi check and told the SA for the 2nd time about premature SC shutoff due the weak pump. They finally were able to pull up a service bulletin about it and placed it. No more heat sink. All was done under warranty.
Clutch engagement is now much smoother, despite no mention from me. I don't think they changed the clutch pack.
