*** VRP Bullet Trans ***
Old 02-14-2008, 12:58 AM
SUNILP's Avatar
2015 E250D
The new transmission was installed today in Mike's car. Install went smoothly.
Old 02-14-2008, 10:26 AM
vrus's Avatar
2003 E55 AMG
Guys.. I made a big error on my post.. i just looked through the invoice we received for the work and there was some miscommunication...
The transmission enhancements themselves are: $3950..
The torque converter work was $1295...
This package normally retails for $6700
VRP is able to provide them for: $5,245
You can order the tranny and torque converter separately or as a package.
My apologies for this mixup.. Now that I got the paperwork on what exactly was done I can see the breakdowns in costs...
NOTE
These transmissions are built to spec.. The company that does them can custom tailor each unit depending on usage and power requirements.. This price point is a package we put together for someone who has our VR700 package or similar mods.. We told them what we were after and this is what they delivered to us.
Sorry for the confusion.
Old 02-14-2008, 03:27 PM
jmf003's Avatar
'03 SL55
Originally Posted by vrus
...VRP is able to provide them for: $5,245
My apologies for this mixup...
Victor, that's still a great value for the money.
Old 02-14-2008, 11:31 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
Originally Posted by blackbenzz
Victor, I want it. If you can just confirm that it will work with my car. Whats the stall speed on the torque converter and is it a billet tc or just a modified stock one? Any warranty? Thanks
Bro it will wrk in your car. Trust me!!!!! All the V8 AMG's basically share the same tranny!!! The E55k maybe even more beefier but I cannot confirm. If not I'm sure Vic could send out your tranny.
Old 02-18-2008, 12:25 PM
SUNILP's Avatar
2015 E250D
Here is what was done to the trans:
1. Complete Disassembly, cleaning
2. Spec Clutch Plates
3. Extensive Valve Body Modification
4. Pump Modification
5. Tolerances adjusted to each gear
6. Increased Tolerances
7. Adjusted Stall Speed for Torque Converter
I cannot go into great detail but the above summarizes what will be done to our trans upgrades. Each transmission is BUILT TO SPEC For instance, the above trans will go into a VR700 car and has a stall speed adjusted to +200 to +300 rpms. The entire torque converter is replaced. For warranty to be effective, we must flush lines with a heated fluid wash through the trans cooler lines. Warranty is usually 3 YEARS, 50,000 miles but will vary depending on the actual spec.
Old 07-01-2008, 03:13 PM
blackbenzz's Avatar
haters crazy
Any before/after dynos with just the torque converter?
Old 07-01-2008, 11:48 PM
  #32
NXtremeJeep's Avatar
GT-R
Can someone provide some insight on the weakness of our trannys. It seems the 65 and the e55 share the same tranny. Numerous 65's and e55's are in the 10's and mid/low 11's without any tranny. This leads me to believe that our units are quite strong. Just curious as to what parts of the tranny fail when significant hp is created.
Thanks in advance
Old 07-01-2008, 11:51 PM
  #33
MB Fanatic's Avatar
4 wheels
Thanks in advance
The stock transmission is already very strong, this will essentially make it even stronger so you can run more power. This is an automatic no brainer if you are pushing the VR700 or VRP750 package. Victor/Vadim, is Havoc doing this to his SL55?
Old 07-02-2008, 12:29 AM
  #34
vrus's Avatar
2003 E55 AMG
No dynos yet.. The VR700 car that has the bullet trans is going back to Houston for some tweaking.
Havoc's car will get the Bullet Trans also but only once we have had a chance to thoroughly test everything out on the E55 VR700 car.
Old 07-02-2008, 11:00 AM
  #35
jangy's Avatar
2015 S212
Is there any cheaper alternative to just tweak the TQ converter? that is all i wanted to do for now. Understood it will add stress, but I'd rather break it and upgrade
Old 07-02-2008, 11:01 AM
  #36
jangy's Avatar
2015 S212
Is that the TT on top of the SC plus cams? I'm scared of those cams for now, but I want 700!!
Old 07-03-2008, 10:39 AM
  #37
vrus's Avatar
2003 E55 AMG
We can get the torque converter by itself but I think the price is $1600 or so.. I have to double check. It raises stall speed by a few hundred RPM and has been modified internally but I dont know all the details of what they do to it.
No.. Havoc's car is getting the TT ontop of SC.. This E55 VR700 has everything that Jim's car has plus the bullet trans, bigger headers and some other goodies.
Old 07-03-2008, 10:47 AM
  #38
V12Godspeed's Avatar
Your worst nightmare...
When can we see the preview of his car? Heheh
Old 07-26-2008, 04:09 PM
  #39
blackbenzz's Avatar
haters crazy
Any updates? Is it safe to just do the TC without the trans build?
Old 07-26-2008, 11:40 PM
  #40
jangy's Avatar
2015 S212
Me too. I wanna know some details on the tranny. I've hated the lag of the TC, so I'd be down to just swap that if the tranny would be able to handle all the power.
Old 07-27-2008, 07:16 AM
  #41
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Hey Boss!! Let's get this ball rolling!
Old 07-27-2008, 07:46 AM
  #42
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Go Havoc!
Hey when do you take your trip to the sportsman Paradise?
I'll be prowling the I-10 corridor San Antonio to Jacksonville in Aug.
Old 07-27-2008, 07:53 AM
  #43
Havoc's Avatar
Originally Posted by Yacht Master
Go Havoc!
I drove there the week of the 4th of July. I'll be going back in March, but this time in my SL5.7.
Old 07-27-2008, 07:55 AM
  #44
MB_Forever's Avatar
E63 P30, CL500 Sport
Vic, you mentioned that this package makes the transmission able to handle up to 1200 ft-lbs of torque...... what about the limit for the 722.9 for the 63s?
Old 07-29-2008, 04:28 AM
  #45
E55 RUSS's Avatar
E55K
Any NEWS ???
Old 07-29-2008, 05:03 AM
  #46
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
so the core needs to be a working tranny?
Old 07-30-2008, 01:37 PM
  #47
vrus's Avatar
2003 E55 AMG
It's taking alot of time to make sure every previous stage of mods is perfect.. Right now we are stuck at making sure the 5.7L is perfect and to see how much power we can get out of the platform before TT are added.
Not yet.. The car that has the trans is making its way back to Houston.. Once it arrives we'll get some seat time behind it and provide a full report.
I am not sure about the TC mod alone.. I havent tried it but I dont see why it wouldnt work with the stock trans.. The Bullet trans is just reinforced to handle more abuse..
Originally Posted by E55 RUSS
Any NEWS ???
That's the next order of business once the motor is all done.
Yup.. 722.9 can be reinforced also.. I haven't done one yet, but we will be doing it to the CLK63 cab that is getting the wide body.
Yup.. Otherwise there **COULD** be more costs involved.
Old 09-24-2008, 10:42 AM
  #48
Havoc's Avatar
Waiting patiently...
Old 09-24-2008, 10:47 AM
  #49
blackbenzz's Avatar
haters crazy
Dont hold your breath, its been almost 2 months since the trans was on its way to Houston.
Old 09-24-2008, 12:06 PM
  #50
Havoc's Avatar
I hear ya, but I have a feeling we're about to hear something soon.
Quick Reply: *** VRP Bullet Trans ***
